Fuel line layout - LX
9 replies to this topic
#1 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 26 April 2016 - 05:32 PM
Could someone who has an engine out of their LX at the moment or would have a pic or two of the fuel lines layout as they enter the engine bay up the rail
Also tank end if possible where they go to the plastic vapour canister manifold thing
Standard set up would be good  - inc charcoal canister pipe and all plastic clips
Mine are not here and only have a set out of a UC so unsure if they are the same same but different
#2 76lxhatch
  • 7,207 posts
Posted 26 April 2016 - 06:46 PM
You can't really see much of it once the steering etc is in place, they just follow the top of the inside face of the chassis rail - you will see the holes where the plastic clips go, they hold two fuel lines (one supply and one vent), and one brake line until it gets to the proportioning valve.
Ignore the line locker and brake distribution block, you can sort of see the fuel lines behind them
#3 hanra
  • 10,975 posts
Posted 26 April 2016 - 09:38 PM
LH. May or may not help.
00000000-0000-0000-0000-000000006AA1_zps
#4 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 27 April 2016 - 01:20 AM
I've got quite a few pics of mine before I took them all off as I didn't think I'd work out how they went back on. I'll try and post them up,later
#5 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 27 April 2016 - 08:44 AM
Thanks fella's
looking at which line comes in where  - ie breather would come in on top of fuel delivery etc
Also chasing a std shot of the charcoal canister line and how that ends
Going down the path of stainless lines and have found a bloke who can double flare the brake line
Any additional would be great Brett
#6 Statler
  • 6,318 posts
Posted 27 April 2016 - 08:51 AM
Torviki > LH parts manual > happy days. :)
#7 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 27 April 2016 - 11:06 AM
These pics are what I took, note that the car is upside down, also there is an extra pipe in one photo that is cutoff you won't have that as its a return line only fitted to factory air V8s
Edited by tuxedoss, 27 April 2016 - 11:06 AM.
#8 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 27 April 2016 - 01:17 PM
Hi Col
Parts manual doesn't seem to give enough detail  - one of the first places i checked ( unless the one you refer to is different to mine)
Brett you are a fgucken legend   -- thank you so much
Just goes to show if you have taken a thousand photo's for a rebuild  - go back and take another thousand
You will need them
Cheers all
#9 Statler
  • 6,318 posts
Posted 27 April 2016 - 01:45 PM
I can't find it 'again'. <sheesh>
I was refering to the PDF that Skap put up. It had 3D diagrams of the fuel system layout.
Sorry for the bum steer.
#10 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 27 April 2016 - 03:54 PM
:)  would you have any idea where this is perchance? possibly? Maybe?
I cant find it again in the Torviki
