Mikuni Carbs
31 replies to this topic
#1 adam_73LJ
adam_73LJ
  • 72 posts
Posted 19 September 2016 - 11:24 AM
Hi,
Just wondering if anyone has delt with triple 45mm Mikuni carbs on a holden 6. Any comments, pro's or con's or otherwise. How they compare to SU's and Webbers etc.
Cheers,
Adam.
#2 N/A-PWR
  • 9,639 posts
Posted 19 September 2016 - 12:03 PM
Great choice Adam,
I have spoken to Oldjohnno about the 45mm too,
 but is said that the HSR-42 is the best option,
 as they are a great deal more efficient and is plenty,
 for 250cfm port flow. :)
#3 Peter UC
Peter UC
  • 770 posts
Posted 19 September 2016 - 12:51 PM
I have the HSR-42s on mine. I have no complaints, throttles crisp, tuning was no problems once I realised they don't like a big balance tube in the manifold like SUs usually run. I blanked them off and the big flat spot I had at low speed went away using a Redline manifold.
My cam is a Crow 35626 and I still get 11l/100km on the highway (I do run a 5 speed with 3.08 gears however) and around 15L around town. Cold starting is fine without the choke.
#4 N/A-PWR
  • 9,639 posts
Posted 19 September 2016 - 12:58 PM
Fantastic information Peter,
 could we get a photo of what they look like on the manifold please?
Like button for you too :)
#5 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 19 September 2016 - 02:06 PM
Ohhhh...YES PLEASE..
#6 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 19 September 2016 - 02:42 PM
pics or it doesn't exist lol
#7 _oldjohnno_
_oldjohnno_
Posted 19 September 2016 - 05:59 PM
Be careful - these flow MUCH MUCH more than the equivalent Weber so be very careful not to over-carb your engine. As Peter said you don't want any interconnection between carbs and you want to keep runner volume low; definitely no plenum. And they'll tolerate quite a lot of cam and still remain civil.
#8 _oldjohnno_
_oldjohnno_
Posted 19 September 2016 - 06:26 PM
Don't overlook Keihins FCR range - with sizes from 33 to 41 these are probably going to be a better match for street/strip cars.
#9 N/A-PWR
  • 9,639 posts
Posted 19 September 2016 - 08:47 PM
Keihins FCR,
 thanks Oldjohnno. :)
Like button for you.
 now goes and find prices to compare to HSR
#10 _oldjohnno_
_oldjohnno_
Posted 19 September 2016 - 09:48 PM
As much as I like the HSRs and FCRs I have to say that for any hot street engine I wouldn't even consider anything other than 2" SUs. The old fossils flow much better than you'd expect at WOT, needles are readily available (so there's no excuse for a poor tune) and on a HP per dollar basis they can't be beat. For a maximum effort race engine the HSR's would have a small advantage but on the street a set of unmolested SUs would still be my first choice.
#11 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 20 September 2016 - 06:21 AM
I am planning on putting on my set of HS8s in the next few weeks to test back to back against my 45DCOE webers. I will be tuning with my Innovate LM-2 wideband/data logger .
I rebuilt the 2 inch SUs and put in UP needles, .125 jet... so hopefully they are close...
#12 Peter UC
Peter UC
  • 770 posts
Posted 20 September 2016 - 01:07 PM
I'll post some photos when I get home :)
#13 Peter UC
Peter UC
  • 770 posts
Posted 20 September 2016 - 09:48 PM
As promised
Attached File  Mikunis.jpg   245.38K   17 downloads
#14 N/A-PWR
  • 9,639 posts
Posted 20 September 2016 - 10:09 PM
Very neat set-up Peter,
 thank-you very much, most appreciated Mate. :)
Like button for you
#15 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 21 September 2016 - 06:41 AM
They look great...
#16 _imj411_
_imj411_
Posted 21 September 2016 - 07:15 PM
Never seen them thats cool. Are they after market and new or are they of a old Datsun or something.
#17 _Agent 34_
_Agent 34_
Posted 21 September 2016 - 07:30 PM
peter what manifold did you use any on top shots , it looks like a simple set up
#18 Ice
  • 15,202 posts
Posted 21 September 2016 - 07:34 PM
First time ive ever seen a set on a Torana they look good Peter
#19 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 21 September 2016 - 08:31 PM
Mmm.they sure look good.that redline
manifold is similar in design to warnefords.runners have an s design on
outers for ease of instalation with cars
such as ehs to have clearance off firewalls.
ive been looking at Sonics single mani design
as runners are straight.hes actually looking
into making all 3 runners together.
im interested to know how much of an angle
the mikunis can be set on an incline.i gather
not much more than how Pete's setup is..i
would like them to b a little straighter
Edited by madtoranajzedded, 21 September 2016 - 08:42 PM.
#20 Peter UC
Peter UC
  • 770 posts
Posted 22 September 2016 - 01:03 PM
As above it's a Redline manifold, I was going to use an old Cain or Armors setup but I couldn't find one when I was looking and the Redline seemed all that was available at the time. Besides the drop in flow through that kink would be minor at best. I actually spoke to Ian Tate about it before I bought one and he uses them and has no issue.
The setup is pretty simple, the place I bought them from extends the throttle shafts so they can be joined with a solid shaft (8mm from memory) using rod clamps. The throttle cable is the standard one and connects to the carbs with a clamp on mount onto the throttle connecting shaft and the cable sheath mount is a simple bracket made up.
#21 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 22 September 2016 - 02:41 PM
Thanks for that little info Peter.thats
reasuring the the red manifold is good to use
I overlooked it at first and have been trying
to find warneford without much success.
near same in design .a setup i found with
with mikunis on had a great linkage setup
Your linkage setup is even simpler and very
tidy..can i ask where did you get your
setup through that extends the throttle shafts
for ease of installation...
Cheers maz
Attached File  j&s 1 001.JPG   192.32K   14 downloads
#22 jd lj
jd lj
  • 2,113 posts
  • Name:James D
  • Car:LJ SVO
Posted 22 September 2016 - 03:02 PM
So do these use a Stromberg /SU bolt pattern to mount them?
It's good to see someone doing something different for a change.
#23 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
into making all 3 runners together.[/quote]
If all three runners were together i wonder if two carbs would be enough as you would draw from both carbs with each inlet pulse.
#24 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 22 September 2016 - 07:22 PM
They use these fittings James
Attached File  images (1).jpg   8.62K   3 downloads
#25 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
Posted 22 September 2016 - 07:26 PM
Wouldnt 3-4 get more juice then than 1-2 5-6 ?
Or one carb fedding 3 .
Edited by madtoranajzedded, 22 September 2016 - 07:27 PM.
