Curious as to what people have done with the parkers on their LX Hatches. This is what I currently have in mine, H4 Conversion but no provision for a parker in the light itself. Getting a new light with parker built in (ie Hella 1058) will mean cutting into the metal backing plate, which I would like to avoid if possible. At the moment the previous owner as just cut holes into the rubber boots and silasticed the old plug in parker base so it shines through the slight gap you can see at the bottom of the H4 lamp. Bit hard to see in the second pic...
Contemplating leaving the headlight as is and getting an LED aftermarket park/turn combo and fitting that where the existing indicator is. Something like this...
http://www.ebay.com....AgAAOSww3tY5V7N
Thoughts??
Edited by Craigie, 25 April 2017 - 11:35 AM.
