LX front shocks
Posted 22 June 2017 - 04:40 PM
Measurements fully extended and full compression if possible?
I am looking into a coil over setup.
Posted 22 June 2017 - 05:21 PM
Can't remember the lengths but I can tell you they are different lengths OEM for 4/6 and 8cylinder...
Maybe consult an old Monroe parts book.
Posted 25 June 2017 - 09:57 AM
There is another company making kits now and they have a brace for lower arm, its still not a proper traditional coil over tho, uses the conical shape spring.
Posted 25 June 2017 - 10:26 AM
It is def possible to fit a quality coilover setup and i know of a few cars with them.
Standard front shocks lengths are irelevant as both upper and lower shock mounts require alot of fab work and moving.
The lower mount on arms requirs opening up lowering about an inch then strengthening, this allows for a better more controlled bump stop not just a solid piece of rubber.
Posted 26 June 2017 - 02:18 PM
I got some from my hatch I can measure if you don't have the info yet
Posted 08 July 2017 - 03:53 PM
Hi mate that would be good what brand is yours any photos of how it's bolted in?
Been looking at this
Posted 08 July 2017 - 09:45 PM
My car is away st the moment but I just brought a set of viking double adjustables from McDoland bros
Just have to remortgage the house to pay for em that's all lol
That pic you got is how they bolt in. Do you want the closed and extended lengths? I'll measure my standard shocks if that's what your after
Posted 08 July 2017 - 11:09 PM
That would be good mate yes thanks.
Posted 13 July 2017 - 05:44 PM
Sorry for the late reply mate. Been flat out
The ones that were in my hatch when I brought it are Pedders GSR9033
From the top or end of the rod to the centre of the lower mount is 365mm open
Closed is 255mm
Hope that helps
Posted 15 July 2017 - 06:25 PM
