help getting correct shifter for my lx torana with VB comm trimatic wanted
9 replies to this topic
#1 _livo74_
_livo74_
Posted 22 August 2017 - 05:18 PM
(copied from my thread)
howdy!!
car didn't come with a shifter installed.
a th400 ?? (or what am told is one) was thrown in with the car.
the "throw" at the bottom "arm" does not match my trimatic.. so...
figured i would give a uc shifter a go.
myself, am not having as much success at using a UC shifter as others, darn it!
3 things appear to be stopping me
1. the pivot point is about 2 inches forward than a torana console/shifter, and would never let you get in park.
2. it stands on a completely different angle.
3. it is an inch higher than needed (at the chrome stick's "join") and therefore doesn't clear the underneath of auto console, at all.
(uc shifter mounted in pics)
Attached File  IMG_2632.JPG   109.96K   1 downloads
Attached File  IMG_2633.JPG   75.84K   1 downloads
Attached File  IMG_2634.JPG   84.57K   1 downloads
(if moved entire shifter back and re-cut hole, and took to fornt of tunnel will the a sledge hammer and lowered it about 2-3 inchs.. it just might?? work. not doing that though.
on the positive side.. the "throw" is perfect and i can finally shift thru gears for the first time.
that i have enjoyed!
is another shifter suitable??
what is the possibiltiy/complexities of taking the lower "arm" off the uc one, and mounting on my other shifter.
aaargh! double aaargh!
#2 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 22 August 2017 - 08:04 PM
get rid of both uc and th400 shifters and get a shifter from a trimatic HX
#3 _livo74_
_livo74_
Posted 22 August 2017 - 08:08 PM
cheers troy, will look into now.
lower "arm" needs to be on passenger side. hope is!
#4 _livo74_
_livo74_
Posted 22 August 2017 - 08:22 PM
all the hx's ive found the arm seems?? to be on drivers side.
found this one.. doesn't mention Hx..
but as don't know what i'm looking for.. don't want to make a mistake
and for all i know this is a th400 or 350.. and the seller is unaware?? just my luck lol!
https://www.gumtree....x-lh/1155072238
Edited by livo74, 22 August 2017 - 08:23 PM.
#5 UCSLE
UCSLE
  • 710 posts
  • Name:troy
  • Car:Goggomobil
Posted 22 August 2017 - 08:23 PM
double check before you buy , my shifter came out of a hx but may not have been the original
went though the same problem with the th400 shifter after a wreckers sold me the wrong shifter
#6 _livo74_
_livo74_
Posted 22 August 2017 - 08:29 PM
am worried might have same experience. a lot of money for a shifter i cant use.
makes bloody difficult that i have a comm trimatic with the arm needed on pass side.
would also consider taking the lower arm off the uc shifter and mounting it on the th400 i've got, if anyone knows how to remove/undo the "pin/axle" they are slid on.
#7 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 23 August 2017 - 08:32 AM
Not sure if ALL shifters are the same, but as for the left and right, I know some of them you can simply knock out a roll pin that holds the pivot pin in place and dismantle and reassemble with it as a left rather than a right side shifter.
#8 _livo74_
_livo74_
Posted 23 August 2017 - 05:43 PM
"simply knock out a roll pin that holds the pivot pin in place and dismantle and reassemble"
.. with.. in my case.. the uc's lower arm onto the th400 shifter.
which would be the cheaper option.. (so i don't have to go out and buy a lx trimatic shifter and swap itself from right to left.)
that would be excellent.
as you mention.. whether all shifter arms are same and can transfer one shifters lower arm and it "slides neatly on" to another is anyone's guess.
if not.. get another lx and do the right to left swap on it.
and.. don't spose you have/know of a vid of how to dismantle handy?? ;)
#9 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 23 August 2017 - 06:30 PM
Yeah ,they have roll pins that hold the lever on one side of the shaft and a spacer in place on the other ,and it looks like they can be swapped from one side to the other ?
Have a look on the under side of shifter , should be able to see the roll pins ?
#10 _livo74_
_livo74_
Posted 23 August 2017 - 07:19 PM
Heya eunuch, will post some detailed pics of shifter as not 100% sure of what pins etc are talking about.
Will post them asap
