has anyone ever fitted a lc/lj torana asr street comp oil pan to a holden 6 with a sonic injection crank girdle? was wondering if the oil pan is a bolt on fit without any modifications due to the crank girdle.
crank girdle/asr oil pan holden 6
Posted 23 August 2017 - 12:56 AM
Posted 23 August 2017 - 01:41 AM
Can't comment about the ASR sump but the std LC/LJ sump needs a massage where the studs are towards the front side of the sump.
Posted 23 August 2017 - 10:23 PM
Oh yeah, and I had to swap to the smaller ARP nuts for one of the studs.
Edited by SA EH, 23 August 2017 - 10:27 PM.
Posted 23 August 2017 - 10:36 PM
There's not much depth left for the Allen key I can tell you.
Edited by SA EH, 23 August 2017 - 10:41 PM.
#5 _duggan208_
Posted 26 August 2017 - 12:07 AM
Thanks I needed to see that too, more bloody work coming up.
regards
Posted 26 December 2017 - 06:22 PM
Hi SA EH, how did you go with the oil pick up.
Posted 28 December 2017 - 02:40 PM
Posted 06 January 2018 - 09:49 PM
So the pick up has been fabricated, welded to a flange that bolts from the inside to a steel block that is tapped for the dash 10 fitting on the outside, this goes to the pump. The original pick up hole has been tapped & plugged off.
#9 _duggan208_
Posted 08 January 2018 - 12:35 AM
Cool.
Posted 08 January 2018 - 05:33 PM
Very nicely made, Thanks for the Pix
I was wondering if you went external with the oil pick up pipe.
Posted 09 January 2018 - 10:36 AM
Is that pickup an off the shelf item and then modified to suit? Also what sort of clearance do you have between pickup and bottom of sump?
Posted 10 January 2018 - 02:02 PM
