Posted 06 August 2018 - 06:26 PM
Posted 06 August 2018 - 06:37 PM
Posted 06 August 2018 - 06:56 PM
Could be for a different trans but same bolt pattern? Does the bellhousing bolt up to your motor?
Posted 06 August 2018 - 06:57 PM
Posted 06 August 2018 - 08:21 PM
This is a VS 5lt bellhousing, looks like yours -
This is a V6 VS T5, looks like yours -
I think someone's been playing part swapsies...
Posted 06 August 2018 - 08:30 PM
Pinched this pic from google as I couldn't be bothered going through all mine -
This IS a v8 box, you can see where the shape of the front face matches your bellhousing.
IIRC the main difference is input shaft length, if yours has been changed it should work, if not, lose two pistons or chuck that box!
Posted 06 August 2018 - 09:05 PM
guess ill measure the shaft length tomorrow and check it against the v8 shaft length? then assume its the wrong bellhousing, part numbers says vr v8 but nothing on the bellhousing
Posted 07 August 2018 - 08:01 PM
Posted 07 August 2018 - 08:15 PM
Fair enough, I've seen my share of T5's but I'm not an expert - and if it fits then its all good anyway
Posted 09 August 2018 - 08:39 AM
The VR box is the odd one.
Check the Dellow site for measurement
Posted 09 August 2018 - 01:32 PM
"odd one" = good or bad??
I've never seen it done but if you were handy with a TIG and a milling machine I reckon it wouldn't be too hard to move the shifter forward on the existing extension housing yourself?
Just shorten the shift-rod (hardest part would be drilling a new roll pin hole) and weld up a new mounting "box" out of ally further forward.
Way cheaper than sourcing parts from a ford if you had the necessary skills?
Posted 09 August 2018 - 02:08 PM
Posted 09 August 2018 - 03:16 PM
Okay I take it back, didn't realise just how cheap ford parts are... that's a bargain at $75!
Posted 20 September 2018 - 11:00 AM
