Clay
Posted 31 August 2019 - 09:06 AM
Posted 31 August 2019 - 10:20 AM
Yep that's a K,T,G steering box.
Posted 31 August 2019 - 10:28 AM
Posted 31 August 2019 - 02:52 PM
Check the top adjacent to the cover. Looking from the front, bottom left is a date code. Top left will have 16.7:1 if it is from a car with power steering or a GTS or another car optioned with the 16.7:1 steering.
Is it out of a HD-HR or similar? Looks like a mashup of different vehicles.
Posted 31 August 2019 - 07:36 PM
Posted 01 September 2019 - 09:30 AM
Can you do a similar conversion to a HD-HR front end without drop stubs? I have been toying with buying a HD-HR of some sort (like a good car that needs not much work), as I need a home for the 307, powerglide and 2.78 LSD banjo that is coming out of my HK GTS. It will all bolt straight into a HD-HR and even the column shift hooks up to the HK V8 powerglide crossover mechanism and the HK V8 powerglide crossmember goes straight into a HD-HR. But the biggest pain is I'd need better brakes than standard HR, so I'd just run the HK's rear drums and possibly HG front with 14" wheels. But I wouldn't want drop stubs as I do not like lowered cars, not massively lowered anyway. The Engineer may not like the 307 either, but that is easily fixed (I have a heap of 283's in the shed).
How much mods were required to make the HK-HG steering box fit? Did it also use a HK-HG column?
Posted 01 September 2019 - 12:47 PM
Posted 01 September 2019 - 01:04 PM
Posted 01 September 2019 - 01:36 PM
Thanks, cool info. No interest in V6 or red 6 or even Holden V8 in a HD-HR. SBC or nothing! I have seen the complete engine and box (307 and 'glide) from a HK V8 dropped straight into a HR using all HK mounts and crossmember. It all fits, they are basically the same car as far as the engine and box are concerned. a HK is basically just a modified HR.
I wouldn't bother with HR discs, way too expensive for what they are, and too small. Same with Torana. HQ would work, but would just mean getting some axles made with HQ pattern on them and run HQ drums on the back rather than HK. If HQ stubs and calipers work though HK-HG stubs (same as HQ) and brakes should work. I am putting a Rodshop front end into my HK with a Territory power steering rack and Astra electric pump, so I could do the same with a HD-HR but just run the standard XF rotors and VS calipers they use (my HK on has the upgraded AUII-FG rotors and calipers) so it could run 14" rims. The original idea was though to use the HK SBC sump with the standard HD-HR steering. I'd only be running 5" rims with something like 185R14 tyres so no problem with steering being heavy.
Will think about it once the HK is finished. I saw a really nice HR ute the other day, stock 186 auto with all drums, doesn't need anything doing to it, just the clunker driveline removed and upgraded. It was less than $30k, registered. Got me thinking.
Posted 01 September 2019 - 02:28 PM
Posted 01 September 2019 - 02:39 PM
Posted 01 September 2019 - 03:08 PM
HK is in reality a modified HD-HR. When you have them fully apart you can see the similarities. I was looking at a HD wagon bare shell next to a HK shell recently and you can see how close they are and how GMH modified them. The floors are very close. The leaf springs are virtually the same. They just widened the car a little. I know they are tighter than a HK in the engine bay but a HD-HR 6cyl and powerglide will fit straight into a HK and vice versa. Same with the 307 and SBC powerglide, using the HK V8 gearbox crossmember of course, but goes staright onto the HD-HR engine mounts. I get the steering box and exhaust clearances. The car I've seen done just used HK exhaust manifolds from memory but it did have different steering.
I was never intending to use a HK axle, just the V8 banjo centre with appropriate HD-HR housing mods to accommodate.
Posted 01 September 2019 - 04:04 PM
Posted 03 September 2019 - 10:27 PM
Posted 04 September 2019 - 09:03 AM
Standard FE HR is 16:1 similar to close ratio HKTG.
Not quite so. FE to EJ is 14:1, EH to HR is 16:1. It doesn't sound much but it is noticeable.
Dr Terry
Posted 04 September 2019 - 12:29 PM
