Heater Box Bypass
14 replies to this topic
#1 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 25 November 2019 - 08:35 PM
Hi fellas,
I want to tidy up my engine bay and as I won't be needing the heater I want to bypass it to remove the hoses.
Can I just put end caps on the inlet and outlet of the Thermostat or do I need to run a pipe between them to circulate the water?
I am planning on using the end caps like below if I can.
Edited by Gatti, 25 November 2019 - 08:35 PM.
#2 Ice
  • 15,202 posts
Posted 25 November 2019 - 09:26 PM
Ends caps are fine some people join them
#3 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 25 November 2019 - 11:06 PM
You could be proper tidy and put an EH HD lower housing on Matt. I wouldn’t trust them new fangled caps. 8)8)
#4 S pack
  • 15,723 posts
Posted 26 November 2019 - 06:28 AM
Not if it's a later model cylinder head that has the extra hole to suit with the later type housing.
#5 meanmachine72
meanmachine72
  • 2,036 posts
  • Name:Jono
Posted 26 November 2019 - 07:33 AM
used those caps before and found they blew out, even when new
#6 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 26 November 2019 - 07:34 AM
One hole is blind and the other gets plugged so not that tidy really. Weld or plug the outlets and fit caps over the top then.
#7 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 26 November 2019 - 07:58 AM
Yep same thing happened to me with the old track car at Calder.
Got everyone's attention that were following me :)
#8 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 26 November 2019 - 09:37 AM
Thanks fellas.
Looks like I'll use a short hose as a loop to avoid the end caps blowing out.
#9 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 26 November 2019 - 09:46 AM
Hard to find one with the radius so you generally need to fold the hose, which leads eventually to failure and looks rough. You can weld up with a stick welder using rods for cast iron or tap and bung with sealant on the threads. Then caps cover the aesthetics. But really they did it from the factory so just fit caps.
Sent from my SM-A705YN using Tapatalk
#10 Ice
  • 15,202 posts
Posted 26 November 2019 - 10:08 AM
Ive had them on several engines never had one blow off yet
#11 Dr Terry
Dr Terry
  • 3,325 posts
Posted 26 November 2019 - 10:52 AM
Blue motor 6-cyl in VC/VH/WB etc. had a moulded by-pass hose which will do the job. It fits over the 2 nipples on the manifold side of the thermostat housing.
Mackay p/no. CH1170.
Dr Terry
#12 claysummers
claysummers
  • 3,635 posts
  • Name:Clay
Posted 26 November 2019 - 12:07 PM
Some times I think I should be more patient, shut up and wait for Dr Terry to chime in. 8(
But where is the fun in that. 8)
#13 Gatti
Gatti
  • 344 posts
  • Car:LJ 2 Door
Posted 26 November 2019 - 12:34 PM
Thanks again.
I'll go with the plugs as it will look neater and just keep an eye on them
#14 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 November 2019 - 07:42 PM
Tap them, fit grub screws & sealent as stated, put caps over the top, never have a problem. I've had those caps split a few times, shit things.
#15 S pack
  • 15,723 posts
Posted 26 November 2019 - 08:03 PM
I put caps on mine many many moons ago when the heater core decided to leak. Probably had them on for a couple of years until I got around to pulling the heater out and having the core replaced.
Never had a problem. I think I might still have them. They were from GMP&A.
