LH Torana Diff Bump
19 replies to this topic
#1 _Anth 05_
_Anth 05_
Posted 12 March 2021 - 10:34 AM
Hello Everyone,
I'm having trouble with one item on my LH and it's holding things up with the rebuild. The Diff Bump Mount. Mine was removed during the rebuild for a repair and now it can't be found. I've tried to locate one but they are hard to find so I've found out.
I was wondering if someone would be able to give me the measurements of one so I can have one manufactured.
Anth
Attached File  Diff Bump Mount.png   468.09K   7 downloads
#2 Bigfella237
Posted 12 March 2021 - 11:11 AM
If memory serves, they were only fitted on 5.0L cars, which likely explains why they're hard to find?
#3 arrimar
arrimar
  • 3,134 posts
Posted 12 March 2021 - 11:27 AM
They are on more than just 5.0L's.
You'll find one on an LH 4cyl or some UC too.
The plate is 114mm x 45mm x 3mm
Hole ccs 88mm (check your floor)
Rubber block 45mm x 45mm x 56mm tall
Chamfer is 8mm x 15mm on front and back edges. (8mm on top, 15mm down sides.)
An HQ bump stop might get you through but Torana is a different shape.
If you use a diff other than standard it might bottom out earlier than desired anyhow.
#4 hanra
  • 10,975 posts
Posted 12 March 2021 - 11:53 AM
Yeah that was deleted on my Oct 75 L31.
#5 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 12 March 2021 - 12:55 PM
U.C.? I thought they were only on the early L.H.s. (up to Sept '74)
#6 308 Sunbird
308 Sunbird
  • 973 posts
  • Name:Stuart
Posted 12 March 2021 - 03:39 PM
My 77 LX Sunbird that l turned into a Club car had one. I remember drilling out the spot welds for the bracket when the 9 inch went in.
#7 dale
dale
  • 76 posts
  • Name:dale
  • Car:ss hatch
Posted 13 March 2021 - 03:25 PM
There isn't any on my 76 SS hatch [ L32 ]
#8 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 14 March 2021 - 09:45 AM
Wasn't the pinion bump & bracket only on models that had the small or large Salisbury diff?
My 2x 5litre SS's with the Banjo diff don't have it.
#9 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 14 March 2021 - 07:38 PM
My 6 cylinder hatch has one fitted to it
#10 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 15 March 2021 - 01:01 PM
Definitely on early LH 4 cyl Ando.
#11 hanra
  • 10,975 posts
Posted 15 March 2021 - 03:47 PM
The GMH Workshop Manual and parts manual contradict...  One says its fitted to all flavors, the other said only fitted to certain flavors. VB & VC but not VD.
#12 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 16 March 2021 - 09:35 AM
Definitely fitted to some VD before Sept '74.
#13 hanra
  • 10,975 posts
Posted 16 March 2021 - 10:09 AM
Yep that def seems to be the case.
#14 hanra
  • 10,975 posts
Posted 16 March 2021 - 10:16 AM
Stolen form fb
#15 yel327
  • 13,643 posts
Posted 16 March 2021 - 10:21 AM
You have to be careful of Parts Catalogues. They aren’t a historical record and can be misleading. What is printed there may mean something entirely different to what it means on first read.
#16 hanra
  • 10,975 posts
Posted 16 March 2021 - 11:12 AM
My Oct 75 L31 VD Body has no provisions for this.
#17 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 16 March 2021 - 03:04 PM
What car was the facebook photo of Brad?
#18 hanra
  • 10,975 posts
Posted 16 March 2021 - 03:15 PM
Tony Natoli's Im pretty sure.
#19 Shiney005
  • 9,604 posts
  • Car:Toyota Mirai
Posted 16 March 2021 - 03:30 PM
I think his car had the MPH speedo so would be an early one. Is it an original 5000?
#20 _Anth 05_
_Anth 05_
Posted 11 April 2021 - 10:48 AM
Hi Everyone,
It's taken a long time to get back to it. I just wanted to thank you all for the information provided. Hopefully I can get this sorted now and keep progressing.
