engine numbers for LJ GTR's
12 replies to this topic
#1 torry nut
torry nut
  • 1,471 posts
Posted 19 December 2005 - 09:55 PM
Can anybody tell me the prefix that LJ GTR blocks came out with ??
L
#2 _@milco@_
_@milco@_
Posted 19 December 2005 - 10:46 PM
L
JL
#3 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 20 December 2005 - 01:57 AM
JL
#4 _gm3300_
_gm3300_
Posted 20 December 2005 - 09:12 AM
the JL prefix engine was also available on "S" and "SL" models when the 3300 became an option for all models. Not sure of the exact date, Dr Terry would know.
The JL motor is identical in every way to the QL motor fitted to HQ's (single stromberg, single branch exhaust, same cam, non-adjustable rockers) the only difference is the use of the low-impedance air filter, and a chrome rocker cover with silver filler cap. Very late GTR's used the standard air filter assy, connected to the rocker cover via a gauze filter in the filter.
grant
#5 _dave720gtr_
_dave720gtr_
Posted 16 January 2006 - 07:58 PM
:blink: :blink: GRANT My GTR 5/72 JL202 donk has never been touched from new looks
Totelly factory original and untouched and its got the ww2 two barrel carby
and 2piec headers the xu1 tipe. and crome/ air /tap cover
I thourt all the LJ gtr,s had this ?????????
:blink:
#6 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 16 January 2006 - 08:04 PM
LJ GTR's did not have the WW Stromberg fitted, this was sometimes fitted afterwards in the 70's by people like me who wanted more power. The JL Torana motor was fitted with the single throat stromberg. I just happen to be looking for a genuine JL motor at the moment - if anyone knows of one lying around gathering dust :D
Edited by surfmaster, 16 January 2006 - 08:06 PM.
#7 _dave720gtr_
_dave720gtr_
Posted 16 January 2006 - 08:54 PM
Would Dr terry confirm this /please / as all the other lj gtr,s but one i have seen
had the two barrel ww2 on the factory manifold as used on 186s
i COULD BE WRONG GM3300 AND SURFMASTER MAY BE RIGHT
I WAS WRONG BEFORE WITH THE WHEELS
#8 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 16 January 2006 - 08:57 PM
Dave, LC 2600 & 2850's had the WW strommy, LJ's were just the bog standard JL 202 with single throat strommy. (Did I say I was looking for a JL motor??)
#9 _dave720gtr_
_dave720gtr_
Posted 16 January 2006 - 09:05 PM
Thanks as i only have a work shop manul for yhe LC and it shows the ww2
as an opps couldent work it out thanks man / so thats guner have to go not orig :huh:
#10 surfmaster
surfmaster
    Marineboy
  • 2,019 posts
Posted 16 January 2006 - 09:12 PM
Dave,
The LJ was just a stock six, it relied on the power to weight ratio for its herbs, (and it went OK for its era). The LC's had WW stromberg, twin header manifolds and I think (not absolutely sure) a different cam grind. I had a LJ GTR (73 model) in the 70's, I went from single strommy, to WW strommy to 350 Holley (which bolts straight onto the WW manifold) to triple SU's. If you want driveability I would stay with the single strommy, for power triples are the way to go.
#11 Dr Terry
Dr Terry
  • 3,325 posts
Posted 17 January 2006 - 08:20 AM
Hi Guys.
A CK XU-1 cam was factory fitted to the 2850S LC GTR.
Also a 350 Holley won't straight onto a 186S inlet manifold, you need an adaptor plate.
Dr Terry.
#12 _73LJWhiteSL_
_73LJWhiteSL_
Posted 17 January 2006 - 09:06 AM
My September 73 LJ S Four Door parts car came fitted with the 202 JL from the factory. I am pretty Sure hg350 has verified the numbers are all correct.
I am planning on rebuilding the JL with some go fast bits and dropping it into the LJ SL to replace the stock CD block.
Steve
Edited by 73LJWhiteSL, 17 January 2006 - 09:06 AM.
#13 salxu1
salxu1
  • 129 posts
Posted 22 January 2006 - 07:37 AM
there is a JL Western Wreckers at Riverstone in a LH
Ian
