grinding metal from brake calipers ( a9x style )
66 replies to this topic
#51 _barbados1212_
_barbados1212_
Posted 21 January 2013 - 03:48 PM
yeah, ok. so i have wb one tonner stub axles, girlock alloy calipers, new hq rotors, harrop steering arms and uc top arms (re-drilled to lower mounting position). is this pretty close to what the a9x's came out with? not trying to do a mock up or anything, just want it to handle ok (alloy headed sbc with a 6 speed t56, 3.7 ratio 9 inch, should be a fairly good high speed cruiser).
a9x's have the caliper at the front i believe?
thanks,
stu
#52 76lxhatch
  • 7,215 posts
Posted 22 January 2013 - 06:32 AM
Yes on all counts, only possible issue you may have is excessive negative camber for street use - see the 'ultimate front end' topic for more details on that (it may or may not be a problem)
#53 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 22 January 2013 - 09:10 PM
As much as I do not like to promote Whitelines line of Chinese quality products, these could be used in your front lower control arms to fix any excessive camber issues with that setup if you go too low or have a slightly sagged subframe.
http://www.whiteline...t_number=W52491
http://www.ebay.com....=item2326ec35ff
#54 _barbados1212_
_barbados1212_
Posted 06 March 2013 - 05:04 PM
Has anyone else found that the centre brake hose bolt hits on the crossmember at normal ride height? The calipers are off a WB and they have been ground down to fit on the front of the disc. Also looks as though the caliper will hit on the top control arm if suspension is compressed on full lock.
Edited by barbados1212, 06 March 2013 - 05:08 PM.
#55 76lxhatch
  • 7,215 posts
Posted 06 March 2013 - 06:57 PM
Full suspension compression or droop at full lock isn't generally a concern, you have to be doing something quite strange to achieve that.
Compressing the piston against the cross member like that is though, the HZ calipers have the line attached in a different spot which is more out of the way (although longer hoses are desirable if not necessary).
#56 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 06 March 2013 - 08:10 PM
Yep, just like the old CRS Commodore brake conversion for drum brake stub axles. I had it hit so hard going over a speed hump that the fitting loosened. So I had to drive home using the park brake only.
#57 TerrA LX
Posted 07 March 2013 - 03:09 PM
Full tilt gutter to gutter will do it, mate had a telegraph pole confirm it with his hatchback.
#58 76lxhatch
  • 7,215 posts
Posted 07 March 2013 - 05:29 PM
That kinda proves the point, eh?
#59 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 07 March 2013 - 08:45 PM
Maybe I should've mentioned mine fouled whist only taking a mild turn, definitely NOT on full lock. Full lock turns created other issues.
#60 76lxhatch
  • 7,215 posts
Posted 07 March 2013 - 09:05 PM
That's not so good, the main problem with the images posted by barbados1212 above is that when the caliper makes contact its in such a manner that it could cause the piston to compress back into the caliper body. Particularly as the pads wear this means that there is some piston travel required before clamping the rotor, if this travel is more than one stroke of the brake pedal you could find the pedal on the floor at next application with no brakes!
Its possible that a shallower head on the banjo bolt may allow enough travel for the specific setup above, although what Vick says doesn't sound promising. I don't see why you couldn't block that hole and drill another in the caliper to fit the hose in a different spot.
#61 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 08 March 2013 - 08:10 PM
#1 The main problem with the images posted by barbados1212 above is that when the caliper makes contact its in such a manner that it could cause the piston to compress back into the caliper body....l you could find the pedal on the floor at next application with no brakes!
#2 Its possible that a shallower head on the banjo bolt may allow enough travel for the specific setup above.
#3 I don't see why you couldn't block that hole and drill another in the caliper to fit the hose in a different spot.
#1 That was the other problems that happened near full lock. I soon learnt that first I would put my foot hard on the brake BEFORE attempting to turn the car on full lock. That way the caliper would act as the new steering stop, rather than drain the caliper of fluid and finding the brake pedal on the floor.
#2 On full lock with the Commodore caliper, you would need a narrower fitting on the brake line AND a countersunk banjo fiting to REDUCE the problem listed in #1.
#3 You could block the hole, but the problem would be making sure the brake line sealed 100%. Impossible in your garage, but possible with the right (and expensive) machinery.
#62 dattoman
Posted 08 March 2013 - 08:23 PM
Or you could remove the caliper Holden never put on a Torana... and replace it with one everyone else uses
Theres a reason no-one uses WB calipers... now you know what it is
I'd be tossing them aside and fitting the cast iron HQ ones
And even then... keep an eye on your clearances cause you can still have calipers bumping into control arms and causing problems
#63 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 08 March 2013 - 08:35 PM
I did my conversion last century, a few years before I bought my first computer. Which was aboput a year before I first got home internet. After about six months, I did what Neil said and pissed off the calipers and put on something less worse. The brake problem was finally fixed when a friend of mine wrote the car off. The brakes were not the cause.
edit - i need a spel chek
Edited by Vick, 08 March 2013 - 08:35 PM.
#64 _barbados1212_
_barbados1212_
Posted 10 March 2013 - 05:30 PM
Datto, I am wondering why you never mentioned NOT to use the WB caliper when you spoke of them in your first post on this thread?? I thought the purpose of this website was to draw on each others' experiences in their field...
#65 dattoman
Posted 10 March 2013 - 08:39 PM
Even I can't remember back 8 yrs ago as to what was going on in my head when I made that post
I've always been an advocate of using the HQ caliper with kidney shaped pad
What people attempt to use is abit up to themselves
People still use UPC brake kits when told of the failings cause they think they are saving a couple of hundred bucks
So I guess people don't actually listen to alot of advice anyway
#66 _Kyetime_
_Kyetime_
Posted 14 September 2015 - 01:27 PM
Here you go, Torana!
How did you go about relocating the brake lines and bleed nipples? Or did you leave them standard, and intend on removing the calipers to bleed them?
#67 Antelope Hatch
Antelope Hatch
  • 21 posts
  • Name:Ben
  • Car:L32 LX Torana Hatch
Posted 22 July 2018 - 11:43 AM
In regards to calipers touching arms, perhaps the A9X style bump stops need to be considered a part of this conversion?  Obviously GMH found a problem and this was their remedy.
Attached File  IMG_4355.jpg   158.17K   24 downloads
Attached File  IMG_4356.jpg   121.6K   20 downloads
