I have a Pro-Stroke crank in my 355.
Yes, it is a chev crank with a holden end welded on. One big advantage with that is that you can use chev rods and pistons.
They have been around for years and years. They state that they have never had any failure (related to the fact that its welded). They are a proven track record and is a quality product.
If its what you want, then I say go for it!
Pro Stroke? Anyone know them?
, Nov 05 2006 10:24 PM
28 replies to this topic
#26 _LHoon_
Posted 08 November 2006 - 03:36 PM
#27 _rorym_
Posted 08 November 2006 - 03:38 PM
It appears the cut and shut thing is correct..dont really know though..I rang and left a message about purchasing a crank 3 days ago and no reply...so I have made other arrangements....not keen on the cut and shut anyway.
#28 _73lj202_
Posted 08 November 2006 - 08:46 PM
Old days he used cut and weld, maybe now uses real cranks, I have never known of any failures and with motors that spin to the redline.
#29 _@milco@_
Posted 08 November 2006 - 09:20 PM
this is the info they sent to me when i asked about there stroker motors you have to supply the ford crank and block,
a better option is a KIT CULLEN holden 6 stroker crank more $$$$ folding stuff but well worth it i have heard.
PRO-STROKE ENGINES
59 KEMPS LANE, HEATHCOTE, VIC 3523
P.O BOX 584, HEATHCOTE VIC 3523
PH 03 5433-2233 FAX 03 5433-2266
STROKER KIT & CONTENTS FOR STREET/RACE ( STAGE 3 ).
186>234ci CONTENTS:-
3.0>3.8 lt
1 SET ACL RACE SERIES PISTONS
1 SET ACL PREMIUM FILE FIT MOLY RINGS
1 SET ACL RACE SERIES CONROD BEARINGS
1 SET ACL RACE SERIES MAIN BEARINGS
1 SET BLUE/BLACK ENGINE CONRODS
1 SET HI-PERF 8740 ARP CONROD BOLTS
MACHINING:-
PRECISION GROUND 3.600" RACE PREPED CRANKSHAFT 234ci
CRANKSHAFT IS FULLY COUNTERWEIGHTED.
CRANKSHAFT IS TUFFTRIDED (HARDENS CRANK FOR SUSTAINED HIGHER R.P.M.'S) CONRODS ARE MAGNUFLUXED, PIN BORED TO SUIT LARGER GUDGEON PINS,
BEAM POLISHED, SHOT PEENED, FITTED WITH ARP BOLTS & RESIZED.
CONROD SIDE CLEARANCE IS SET FOR YOUR APPLICATION.
CONRODS ARE CLEARANCED TO HELP INSTRALLMENT.
ALL PARTS ARE BALANCED TO STREET/RACE TOLERANCE.
STAGE 3 186>234 HOLDEN KIT C/O KIT PRICE INC. GST $ 2699-00
CHANGE OVER ON ABOVE KIT IS A 186 HOLDEN CRANK WITH STANDARD MAIN JOURNALS AND A 221 FORD CRANK WITH STD/020 BIG END AND MAIN JOURNALS.
THESE CRANKS NEED TO BE SUPPLIED TO BUILD THE KIT.
NOTE: 1. THIS ENGINE KIT REQUIRES EXTENSIVE BLOCK CLEARANCING,
CAMSHAFT RELEIVING & OIL PAN MODIFICATIONS.
2. THE PISTON SUPPLIED IN THIS KIT IS EQUIVELENT TO .075” O/S.
THANK YOU FOR GIVING US THE OPPORTUNITY TO QUOTE FOR YOU. WE HOPE THIS INFORMATION WILL HELP.
Prices are subject to change. Please confirm at time of order.
PRO-STROKE ENGINES
3.0>3.8 lt
MACHINING:-
