HQ stub axles(spindles)
#26
Posted 21 November 2006 - 09:13 PM
Forward or rear mount doesn't make much real diffference on a street/targa car
#27
Posted 21 November 2006 - 11:15 PM
Posted 22 November 2006 - 11:16 AM
Can you let me know what you settle on as to the best mix of all the UC LH LX LX RTS bits?
Thanks,
Welby
#29
Posted 22 November 2006 - 04:46 PM
I am picking up the spare LH front subframe unit this weekend and have the Wilwoods,HQ slotted discs and UC arms. Will fit new ball joints,tierods nolathene bushes etc As Datto says..I will trial fit the whole unit on the workbench first to see clearences. The Wilwoods look close..will take pics and post what I find.
_bodallafella_
Posted 23 November 2006 - 09:41 PM
#31
Posted 23 November 2006 - 10:42 PM
Posted 23 November 2006 - 11:47 PM
Drag cars don't need big brakes on the front... as they have small contact patch
They use small brakes on the front and Dynalites on the rear
#33
Posted 24 November 2006 - 12:56 PM
I am lowering the Upper arms 25mm,using UC top arms,starting with UC steering arms to see how I go then fitting the brakes forward to see if all clears..I will make a start this weekend if I dont pick up the Toploader in Bris..will keep you posted.
Posted 25 November 2006 - 01:43 PM
Posted 25 November 2006 - 02:32 PM
The UC is the front one..notice the balljoint is off set to the rear.
The UC steering stop
Side by side..UC closet./dirtiest one.
Posted 25 November 2006 - 02:50 PM
_L31SLR_
Posted 25 November 2006 - 02:58 PM
L31SLR
#38
Posted 25 November 2006 - 04:02 PM
UC are offset top balljoint
#39
Posted 25 November 2006 - 04:43 PM
Neil? Dont you confuse me now!!
Charlie...25mm lower than the UC height..50mm down from the flange..I think thats what M@ did..I will go back and check.
Here tis!!
I have redrilled my UC one on the test bed to the same as what is in my car and that front end is an RTS LX front end. The bolts for the Upper control arm are about 50mm down from the flange - you could probably have drilled this one about 3 or 4mm lower if you were after every skeric but I was trying to simulate the setup in my car.
Edited by rorym, 25 November 2006 - 04:51 PM.
#40
_L31SLR_
Posted 25 November 2006 - 07:00 PM
So much for just changing the stub axles!
Are you not going to use the Harrop steering arms?
There is a UC in this blokes drive way down the road in bits and it hasn't moved for the last 18 months. Maybe I should make him an offer!
L31SLR
#41
Posted 25 November 2006 - 07:43 PM
Cause they didn't look very offset to me at first
Mine are cleaner and more obvious
#42
Posted 25 November 2006 - 08:28 PM
_Oldn64_
Posted 26 November 2006 - 07:01 AM
Making the heart pump hard is a good thing..Dattoman..WILL YOU STOP GIVING ME A HEARTATTACK!
Lol!
Posted 26 November 2006 - 07:39 AM
I am going to use the UC subframe..its newer probably had less work and from what I understand it is exactly the same as the LH/X one (cept for the top arms)but has welded steering stops on it. I am starting with UC steering arms as I will be running heaps of Neg camber..
Posted 26 November 2006 - 07:40 AM
Thats better.
Posted 26 November 2006 - 12:04 PM
UC rack mounts differently too
Its the better system so use the UC Xmember
#47
Posted 26 November 2006 - 12:41 PM
_MRNOS_
Posted 26 November 2006 - 04:11 PM
#49
_L31SLR_
Posted 03 December 2006 - 11:08 AM
Went and talked to the guy down the road yesterday about the UC sedan. Anyway cut a long story short he told me I could have it for nothing if I took everything.(Car has been stripped apart for painting. He's even throwing in the paint!) It's a 4cyl auto and looks pretty well rust free. Will post some pics up when I get it home. I now have my front sub frame.
Charlie (L31SLR)
#50
Posted 03 December 2006 - 07:35 PM
I could do with the flat boot floor and I know someone is looking for a rear floorpan to assist fitting a genuiswine A9X Sailsbury diff
