202 or 186. Which is better?
27 replies to this topic
#1 _GTR071_
_GTR071_
Posted 27 November 2006 - 06:12 PM
Was just wondering what motor is better out of the two. Red 202 or 186? Is it true that 202's arent really 'revvy' motors? Also are manifolds etc. interchangable between the two motors. Also wondering the difference between 186s and normal 186.. i've been told 186s have steel cranks? any other differences like compression? and whats the chance of getting my hands on a 186s? :rolleyes:
#2 Heath
  • 18,365 posts
Posted 27 November 2006 - 06:24 PM
lol I do have a 186s, sadly it isn't for sale mate.
186's (and 186s's) run smaller bearings than the 202, and therefore they are more "revvy" naturally.
But I mean any motor can be built to rev; if you get a 202, put a knife-edged, balanced crank in, roller rockers, take out the second set of compression rings etc, it'll rev off its tits any day of the week!
Both 173s and 186s run the same sized bearing journals I think, so they have the same "revvy" nature.
All the manifolds are the same, but the 186s ran a WW Stromberg (which is a twin barrel) - or actually I dunno. I don't know anything about LC/LJs but I know that some of the GTRs ran those carbies, could someone tell me what motor that was on?
But yeah all red top ends are universal i.e. the head of a 186 is the same as a 202 head, but it has different rocker towers.
A 173/161 head will bolt onto a 202/186 and make it a higher comp motor etc.
Until you get to blue/black 12-Port manifolds and heads, everything is interchangeable.
Edit: Don't bother with a 186s. Do you want a revvy motor? A motor with high compression? etc let us know what you're after and we'll give you ways to get it. It isn't worth buying a 186s.
Edited by Heath, 27 November 2006 - 06:29 PM.
#3 _UCV80_
_UCV80_
Posted 27 November 2006 - 06:35 PM
Iv had a worked 179 and a worked 202, i do belive the smaller 6 reved abit quicker, and still had plently of muscle. but the 202 is a bigger and a more beefy engine :D
Should go for a 202 and get it all balanced :spoton:
#4 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Certainly early 186S did...but as comes up here a couple of times a year...every 149, 179, early 161 and 186 did....Dr Terry points to a date somewhere in 1968.
The LJ XU1 (which would have to be Holdens best attempt at extracting power from a red 6) ran a cast crank.
Which is better 186 or 202?
For mine its a 186...only because the 202's i own are a bit lazy...Its not to say some people can't get them singing..its not rocket surgery!
All manifolds are interchangeable..differences between 186 and 186S were: WW Stromberg carburettor, manifold to suit carb, cast headers and higher lift cam. As far as I am aware the compression is the same at 9.2:1. Power for 186 = 130 hp, 186S= 145hp and 202=137hp.
You can get 186S's but its going to need a rebuild...and you can make any red motor go hard as you want it to..with a bit of foldy stuff.
#5 Heath
  • 18,365 posts
Posted 27 November 2006 - 09:57 PM
:huh:
lol, yep FastEH just gave you all the info you should need really. Never knew they had a high lift cam, but I'll take your word for it!
How are the headers different from the standard ones mate? Not following there. You're not talking about the XU-1 headers that are in multiple pieces are you?
#6 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 27 November 2006 - 10:16 PM
Not that I know part numbers or anything..but the 186S has it parentage with the 179 X2 engine in the HD...it had a pair of strombergs, twin strommy manifold, high lift cam. When the HR came out the 179 was gone so it became the 186 X2....when they changed to the 186S all that changed was the carb, inlet and exhaust manifold...as far as i know the cam stayed.
The X2 had seperate exhaust and inlet manifolds.....before that inlet manifold and exhuast manifolds were bolted together to give heat for vapourisation. The 186S had the same cast 2 piece headers as the XU1.
#7 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 27 November 2006 - 10:28 PM
and I nearly forgot..the X2 had a different distributor (different advance curve)...the bottom portion was painted rocket red..I would assume that got carried over to 186S too.
Edited by FastEHHolden, 27 November 2006 - 10:29 PM.
#8 _LH SL/R 5000_
_LH SL/R 5000_
Posted 27 November 2006 - 11:20 PM
From what I have read the 202 is basically a 186 with the stroke lenghtened from 3" to 3.25" and, as mentioned before, an increased main bearing journal diameter. A new block wasn't cast for the 202 for an increase in deck height that was needed, Holden got around the problem by moving the gudgeon pin 1/8" closer to the piston crown, this introduced a weakness in the piston around the lower oil ring groove.
My preference is a 186.
#9 _Keithy's_UC_
_Keithy's_UC_
Posted 28 November 2006 - 06:49 AM
I have owned both (well not a 186, a 179 bored to 186). While the 202 was standard and breathless, the 179 will rev it's tits off and pull hard any time of the day. While i'm now 'biassed' because the smaller cube motor has my tick of approval, i speak from experience when i say that the 202 with a bit of work will make you smile more.
Reason being is that people with 202's will now have 'more cubes' than you. Plus i've seen thrown conrods from both motors, the 202 was at 6000rpm and the 186 was at 7500rpm - neither of which i drove or owned.
Its your choice in the end, if your like me and tend to drive like miss daisy with a squirt here or there you'd probably get more kicks outta the 202 as well. My 179 has got heaps of torque, but a 202 will give you more.
Just for the road, my 179 runs 14's and is more than happy to be street driven (i.e. torque is aplenty and this motor pulls the car along from 1200rpm with great ease).
Cheers and sorry for the confusing words!!
Keith
#10 rodomo
  • 18,019 posts
Posted 28 November 2006 - 02:12 PM
Fact: 202 beat 351 at Bathurst, 186 didn't.
#11 Heath
  • 18,365 posts
Posted 28 November 2006 - 02:29 PM
^ I like that :spoton:
#12 _jap-xu1_
_jap-xu1_
Posted 28 November 2006 - 02:55 PM
some highly disturbing advice there ;)
1.bearing size has nothing to do with rev ability, its all to do with piston speed.
the 186 has a shorter stroke,the piston doesnt travel as far per revolution and therefore will have the same piston speed at a higher rpm than the longer stroke 202.
a shorter stroke engine will rev faster and easier put produce less power per rev.
horsepower = torque x rpm so the same power is there just at higher rpm.
2. i hope your joking about leaving out the second compression ring ;)
i really really do lol
#13 _Keithy's_UC_
_Keithy's_UC_
Posted 28 November 2006 - 03:07 PM
Yeah, it's the other way around with piston rings heath - if you keep adding them the motor will rev harder... The pro's call them speed rings!!
And i'm only havin a go at ya!!
Keith
#14 Heath
  • 18,365 posts
Posted 28 November 2006 - 03:28 PM
haha good idea Keithy!
I'm aware of the shorter stroke aiding the revs; I thought that was a given.
People argue that the smaller bearings have less internal resistance which helps with revs and effeciently turning the motor in the first place, that's why I mentioned it.
The second set of compression rings? Yeah I don't think I'd do that to a car that I own but apparantly it does work very well. People have told me about them doing it in the past and the results don't sound too bad.
LOL!
Edited by Heath, 28 November 2006 - 03:29 PM.
#15 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 28 November 2006 - 04:32 PM
I know of race bikes where they did it..to cut down on friction..and the engines are regularly rebuilt....it not something i go in for.
I have also heard of the narrower bearings having less friction...but lets face it..it really isn't that much.
#16 _MRNOS_
_MRNOS_
Posted 28 November 2006 - 04:48 PM
Just do a 308
#17 _gtrtorana_
_gtrtorana_
Posted 28 November 2006 - 04:52 PM
I think a 202 also won the 1979 around Australia trial. I like 202's but I am biased as I own one.
#18 gooley
gooley
  • 529 posts
  • Name:Jason
  • Car:Holden Torana LC 1970 Coupe
Posted 28 November 2006 - 06:15 PM
well i own both of them the 186 in my LC torana and 202 in my HQ Kingswood Ute......You ask which one is better well i choose the 186 but again the 186 has been worked....has got a lumpy cam and i have heard a rumour that it has been bored out to be a 192 but i am not exactly sure (done by previous owner/s).......but i choose 186
#19 _devilsadvocate_
_devilsadvocate_
Posted 28 November 2006 - 08:06 PM
yes with PB at the wheel, but there were rumours that the gm support crew rebuilt the car(vb commy) every night. Really a stock 202 is better than a stock 186, than a 173 etc........thats why they kept getting bigger. Which can go harder with all the go fast bits, I think the 202 still gets there. Building holden red motors to do 7000rpm, really is pushing........uphill.......cost a fortune......(something to do I suppose) might as well get yourself a bimmer six in the 1st place.
Edited by devilsadvocate, 28 November 2006 - 08:14 PM.
#20 _Keithy's_UC_
_Keithy's_UC_
Posted 29 November 2006 - 07:27 AM
It may be interesting to note that there are more worked 179/186's than 202's getting around... I had a stock 202 and have a worked 179... Maybe it's fate. If you want to work a 6, there is marginal difference but most have said 186. To be different i'm still saying 202. If your spending money on it, may as well beef up the rods and rod bolts so she doesnt throw a conrod in the first place!
Keith
#21 LOWS2
LOWS2
  • 1,483 posts
Posted 29 November 2006 - 08:04 AM
Im getting a 186 built next year, only cause it was offered at bargain basement price & is a virgin bore block so i can pick & choose pretty much anything i want done to it.
I guess it comes down to whatever block you can get your hands on at the time.
#22 _dave720gtr_
_dave720gtr_
Posted 29 November 2006 - 12:33 PM
Think of it this way holden did not build the 202 to go backwards
yes the 186 is more willing to rev but the 202 makes more low down torque,
The last run of 202 lj 73 bathurst xu1s put out more power than
any other red holden as ever made. but hay'every one knows that !.horses for courses :D
#23 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 29 November 2006 - 01:55 PM
The world has come a long way since 1973...remember these things were to power family hacks and builders utes...not necessarily to lap bathurst.
Holden had 3 different goes at the 186...Stock 186 was 130hp, 186X2/186S was 145 and LC XU1 was 160 hp (wasn't it?) So both the X2/S and XU1 slaughter the 202 @ 137hp....but the 190hp of the LJ XU1 puts the 202 over the top.
I'm still the fan of the underdog.
#24 _Oldn64_
_Oldn64_
Posted 29 November 2006 - 08:26 PM
I will jump on board in reference to teh smaller bearing, it is not teh less friction that does it it is the fact that the bearings are lubed easer (in a simple approach). So in essence the crank spins nicer in a 186 block than a 202 block. just what I prefer. Again revvability is about piston velocity, this is what kills a motor, and also why teh f1 cars can rev to stupid revs like 11000rpm.
Yes the 202 will be better in every aspect of the power and torque, BUT the 179/186 family do run smoother. Anyways, after building many many 202's and 186/179's I stil prefer the baby motor.. ;)
#25 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 29 November 2006 - 08:36 PM
What about 173's?
RIM
