Winton or bust!
#601
Posted 26 May 2010 - 09:24 PM
#602
Posted 26 May 2010 - 09:25 PM
Am I reading that chart right?
OA7's are leaner than RH? Correct?
The three carbs tune like out of a text book and there is no missing or farting.
Edited by rodomo, 26 May 2010 - 09:31 PM.
#603
Posted 26 May 2010 - 09:34 PM
How's the V8 coming along ?
It's not. It's been stagnant while this mod has been on the go. Lots of bits gathered though and unlike the 6, it will pretty much full on straight up, not bit by bit.
Once I get this set-up sorted I'll be back onto it and maybe a motor for the LJ too during the cold months.
Edited by rodomo, 26 May 2010 - 09:35 PM.
#604
Posted 27 June 2010 - 02:03 AM
8 super dooper pistons have arrived.
#605
Posted 29 June 2010 - 10:09 PM
id love to rebuild emmas 202 but not gonna bother seeing as it will end up an 8
#606
Posted 01 July 2010 - 12:29 AM
The thread appears to be 3/16th UNF as far as I can identify it. Research also says it is a No. 10 die nut?Basically, if I shorten the adjustable links by 25mm it should work. I just have to identify the thread on the adjustable links and find a die nut.
Fitter and turner needed here as the blokes I have spoken to (tool shops) aren't as sharp as their chisels?
BUT!
The roving R&D team have found the Nissan Pulsar fuel injected throttle body links MIGHT just do the job?
These might be the same as late Camira EFI???? Dunno? At pick a part I just went up the Nissan isle when I saw this linkage?
It is about an inch shorter, has a left and right hand thread and has steel ball pivots.
I also found that these ends will screw onto the original links.
The thread pitch is the same but the OD thread size is .005" bigger.
P.S. I'll learn how to drive Vista sooner or later, bare with me.
Edited by rodomo, 01 July 2010 - 12:34 AM.
#607
Posted 03 October 2010 - 11:25 PM
I've modded the accelerator pedal so I can "heel and toe"
This is the original set-up
You can see how far and disorientated the acc. pedal is from the brake and the angle of a 51 year ankle to get to it, even then just hitting the bottom of the pedal.
So the fabrication team went to work and produced the RoDoMo racing treadle.
(Only available in brushed aluminium finish at this stage)
More pedal to hit.
Also, I've changed steering wheel.
Being a tad vertically challenged, when I had the distance to the pedals right with the seat position, I felt my arms were too bent when steering.
The indicater stalk also had to be "adjusted" with a heat gun to give knuckle clearance.
And while we're on the subject of seating position, as we are all aware of the angle of the steering column to the seat in LC/J, something I noticed while retightening the wheel was the position of the clutch pedal through the steering wheel spokes.
You'd think the brake pedal would be more in line?
There has been further R&D work on the triples as well. Skinnier, richer needles, metal linkages which have also altered the geometry, the poppet valves in the butterflies have been blanked off and a new cable bracket fabricated.
Next race day Oct 17th Sandown
Edited by rodomo, 03 October 2010 - 11:28 PM.
#608
Posted 04 October 2010 - 12:09 AM
You'd think the brake pedal would be more in line?![]()
Braking and accelerating are done with the right foot
Depressing the clutch is done with the left foot but is done a fraction of the time in relation to actual driving ao the left foot is at rest most of the time, this would redice driver fatigue one would imagine.
#609
_Woodsy_
Posted 05 October 2010 - 04:05 PM
#610
Posted 05 October 2010 - 06:58 PM
#611
Posted 05 October 2010 - 07:15 PM
And when you "changed" the steering wheel,did you just sit it on the floor and jump on it?
#612
Posted 06 October 2010 - 04:20 PM
It didn't fit the LJ, it had an LC boss, so I took the wheel off the LC boss and mounted it to the Commodore boss.
You can see the holes in the spokes of the 1st wheel.
Edited by rodomo, 06 October 2010 - 04:21 PM.
#613
Posted 11 October 2010 - 09:48 PM
I'm planning on doing both these.
Would be great to have the Thunderbolt Grease Slapper along...
#614
Posted 11 October 2010 - 09:51 PM
Who's running this?
#615
Posted 12 October 2010 - 05:59 PM
Found it:Phillip Island on 13&14/11
Who's running this?
http://www.piarc.com.au/files/Nov%202010%20Sprint%20Regs.pdf
#616
Posted 17 October 2010 - 12:08 AM
But it's on the trailer
#617
Posted 17 October 2010 - 09:33 PM
It would be a crime against humanity not to drill at least a couple of speed holes in that pedal....
No speed holes but it's got a "roller rocker" arm
I'd fiddled around this week re-tuning the carbies after a couple of mods and thought I had it sorted.
I had a couple of little things to do, refit the grill, extend a vac line to the booster, fit a captive spring to the acc. pedal so it couldn't flip back and fall flat on it's face, change the oil............... little crap.
The rocker gear sounded a little noisy while tuning the carbs so I added adjustment to the list, no problem, 1/2 hr job?
I restarted it Sat. arvo and not only was it rattley, it had developed a miss?
Spark from lead?...... CHECK
Swap plug, any change?........NOPE
PULL FREAKIN' ROCKER COVER OFF???????........... Smashed pushrod, no, not bent, smashed like a snapped carrot!
Bad pic but you can see the rocker out of alignment.
Ring engine builder buddy...............
Me: Why is this happening?
EBB: Because you're a dickhead?
Me: How can we fix it?
EBB: Shorter pushrods, I have some V8 ones here, they're shorter, try them.
So............ drive 1hr there and back, grab pushrods, go home, finish oil change on tow car, try pushrods, too short, dig out a set of standard pushrods, ring EBB and suggest pre-loading lifters?, fit 6, drive Dad to Bingo (25 mins), come home, swap cars, pick up trailer, fit other 6 pushrods, fit grill, drive back 25mins to pick Dad up from Bingo, finish off other crap, load tools and spares into tow car and drive car onto trailer at midnightish.............
But........
Besides all that?
It was great day!
More like a celebrity event?
Neil Crompton was there..................but he didn't race.
The new Stig was there.
Maxwell Smart (Agent 86
And GMH were there with the new concept GEM-T-R-X-U-1
And, of course, the Grease Slapper
Which ran flawlessly all day until my knob fell off.
AND.......I ran a new PB!
1:31.8 which is quicker than Rotten Ronnie and Mad Mick!
#618
Posted 18 October 2010 - 01:28 AM
Two thumbs up.
#619
_2ELCS_
Posted 18 October 2010 - 08:03 AM
#620
Posted 18 October 2010 - 10:35 AM
#621
Posted 18 October 2010 - 12:06 PM
#622
Posted 28 October 2010 - 10:32 PM
Errrr.....Ummmmmmm..........It appears that the sheet posted at the track was a miss-print.
Should read 1:38.1
I've entered this for the Sunday only:
#623
_73LJWhiteSL_
Posted 28 October 2010 - 10:44 PM
Steve
#624
Posted 28 October 2010 - 11:26 PM
From here:
http://www.hsvowners...motorsport.html
The car ran well last time and the plan was to see how it went (and the tow car) further afield at P.I.
Then, if all goes well, make the trek to Winton.
Maybe the fun day?
http://www.wintonmot...ay=12&Itemid=41
#625
_73LJWhiteSL_
Posted 29 October 2010 - 01:35 PM
Been a while since i been to a fun day, usualy the one before Christmas is pretty quiet i find.
Steve
