........Stroker 308.....??
_Barman_
, Jan 04 2007 07:01 PM
4 replies to this topic
_Barman_
Posted 04 January 2007 - 07:01 PM
Well ive checked my rpm on torque converter and when i did this it felt like a twisted towel with the torque.. so my question is how do i measure or identify if it a stroker or not Thanks Guys... Baz
_LX8VD69_
Posted 04 January 2007 - 07:05 PM
the only way i know of would be to take a head off and measure the stroke. other wise you could just be satisfyied knowing it goes hard and live in ignorance of whats in it
_Barman_
Posted 04 January 2007 - 07:16 PM
I thought about stickin a piece of wire down the spark plug hole and comparing it to 308 on engine stand ?Recon this will work ??
Thanks Baz
Thanks Baz
_mark350torana_
Posted 04 January 2007 - 07:37 PM
Hi yes that will give you a pretty close idea with the rod length mate and should be able to tell cheers and good luck.
Posted 04 January 2007 - 07:50 PM
yep, bit of decent wire (so she dosent bend) and turn it over, put a mark on it at bdc then one at tdc and measure it. then compare with 308.
ITS A PLAN MATE!!!
ITS A PLAN MATE!!!
