Ignition switch
_4door_LJ_
Posted 04 January 2006 - 05:37 PM
Just need to know if the ignition switch half way down the steering column is universial btw the old Holdens (HQ - HZ, LJ - LX)
Looks like mine is stuffed on my LJ so I'm hoping any old swich will fit in.
Troy
_Flamenco_
Posted 04 January 2006 - 06:23 PM
Description: BARREL & KEYS IGNITION LOCK HQ HJ HX LJ LH LX so I guess you''ll be fine using a switch from any of those models.
_J&S Racing_
Posted 04 January 2006 - 06:24 PM
_jap-xu1_
Posted 04 January 2006 - 07:58 PM
_dazzaslr308_
Posted 11 January 2006 - 11:04 PM
_monaroman68_
Posted 02 April 2007 - 10:51 AM
Edited by monaroman68, 02 April 2007 - 11:02 AM.
_DocDamage_
Posted 02 April 2007 - 11:05 AM
_CHOPPER_
Posted 02 April 2007 - 11:14 AM
_monaroman68_
Posted 02 April 2007 - 06:50 PM
_DocDamage_
Posted 02 April 2007 - 06:56 PM
_monaroman68_
Posted 06 April 2007 - 08:11 PM
did ya find those pics of the columnI had the same problem with the one tonner. Its not the barrel but either the rack & pinion gear that actuate the switch, or the switch itself. Mine had a broken tooth on the rack. I'll see if I can get you some pics off a spare column I have here.
Dave
_DocDamage_
Posted 06 April 2007 - 08:43 PM
And a closer shot of the gear itself (I can't get the focus any better sorry).
The rod runs down to the actual switch which screws to the top side of the column under the dash.
_monaroman68_
Posted 07 April 2007 - 10:02 AM
Dave
Posted 07 April 2007 - 11:57 AM
unplug connector and use jumper wire with batt on it and touch the plug pins, if starter kicks in then go to switch,
plug off , meter across open cct
turn key, rod moves down and closed cct at switch points.
if not then then check if rod moves down further and cct closes
if not replace slide switch
_Holdenmad_
Posted 06 May 2007 - 10:01 AM
How do I go about replacing this?
do I need a whole new column or is there somewhere I can get the whole rack and pinion new?
Kinda need a quick fix too this is my daily driver, will have to take monday off work to fix it, as my wife needs her car to drive the kids around.
Posted 06 May 2007 - 05:45 PM
take the 2 wires off the switch on column and connect to push button switch,
mount in or under dash
then turn on ignition and push switch to start
Edited by limo, 06 May 2007 - 05:46 PM.
_Jewboy_
Posted 08 May 2007 - 12:43 PM
_Holdenmad_
Posted 08 May 2007 - 03:48 PM
Got a cog from the wreckers for free. Replaced the barrel for $20. Add in the cost of a steering wheel puller, all up it cost me $35 and about half a day of work.
The cog was pretty well stripped, and the barrel took a lot of persuasion to come out, as the little pin thing was jammed. So the barrel was no good once I got it out.
