which engine does L18 stand for. Ive pulled out a front end from a uc and it had L18 for an engine code?
engine code
_355lxss_
, Jan 05 2006 09:32 AM
6 replies to this topic
#1 _355lxss_
Posted 05 January 2006 - 09:32 AM
Posted 05 January 2006 - 06:10 PM
L18 is starfire 4 in a commodore. Would think it was the same in UC. Educated guess only.
#3 _Jaime_
Posted 06 January 2006 - 09:35 PM
Yeah it's a High Compression Starfire 4.
#4 _355lxss_
Posted 07 January 2006 - 09:44 AM
im puzzeld? the front end came out of a uc with a 186 and had 2850 badges on it???
Well my main concern it that the front end will still be suitable for my hatch? Buy comparing my current front end to the starfire one, they both look the same.
Were the 4,6 and 8 front ends all the same?
#5 _CHOPPER_
Posted 07 January 2006 - 09:58 AM
The Starfire motor has the same engine mounts as the Holden 6. Mainly because the Starfire 4 is a cut down version of a Holden 6. If it had an Opel motor, that's when the crossmember has to be chucked. Somebody correct me if I'm wrong.
#6 _355lxss_
Posted 08 January 2006 - 09:39 AM
thanks for that chopper. i can now start to strip it down and rebuild it.
Posted 08 January 2006 - 10:42 PM
I will correct.
If you have an opel frontend you use it to fit a 350 chev.
