[Torviki] Engine Mount Pictures
#26
_the gts_
Posted 09 March 2007 - 02:28 PM
I have a chev sitting on LH 6cylinder mounts but want to lower the motor as much as i can. other option is to modify the adaptor brackets
thankyou
PHIL
#27
_the gts_
Posted 09 March 2007 - 02:31 PM
#28
Posted 09 March 2007 - 04:29 PM
the other car uses the HQ type bracket and the gap is only 13mm.
the top pic is torana with old original mounts 22 mm
the bottom pic is torana with new HQ mounts 13mm.
#29
_the gts_
Posted 11 March 2007 - 08:44 AM
do you have a part number for the HQ engine mounts?
#30
Posted 11 March 2007 - 09:01 AM
#31
Posted 11 March 2007 - 09:18 AM
Standing at the front wheel..facing the left hand bank of cylinders...Yes M@ you are right..Mine are vertical..i.e. do not lean at the top of the mount to either the front or rear of the car.Don't let me hold you back, I'm sure both ways will give the answer we want - just goes to show there is more than 1 way to skin a cat.
Some food for thought though, where are you going to measure to and from on your test front end?
The torana front subframe is a bugger of a thing with almost no straight edges to measure from.
I am going to have to go and have a look at how the mounts bolt onto a holden V8 now - I am about 90% sure they are vertical when viewed side on.
(by side on- I mean if you were looking from next to the front wheel looking at the side of the engine. And when I say vertical I mean the top of the engine mount does not tilt toward the front or back of the car)
_the gts_
Posted 11 March 2007 - 07:06 PM
#33
Posted 11 March 2007 - 07:22 PM
Correct.so where is the rubber in the pics? or is that a bracket that goes between the block and rubber?
_CHOPPER_
Posted 11 March 2007 - 07:30 PM
#35
Posted 11 March 2007 - 08:07 PM
factory pt no 9930472
the site i looked at listed same part no for HQ thru to VT
#36
_the gts_
Posted 12 March 2007 - 08:39 AM
same old story CHEV = Custom made everything
#37
_SS Hatchback_
Posted 25 March 2007 - 10:31 PM
So is this what has been found out , 5mm higher and around 5 to 6mm further forward with the torana mounts?hq mounts move the motor back....difference is about 5 ml from torana mounts..
#38
_SS Hatchback_
Posted 23 April 2007 - 11:30 PM
Anyone for the above question?? Also who on here is selling the mounts? I remember seeing someone was making repo'sSo is this what has been found out , 5mm higher and around 5 to 6mm further forward with the torana mounts?
Edited by SS Hatchback, 23 April 2007 - 11:31 PM.
#39
_Toranamuk_
Posted 24 April 2007 - 12:55 AM
Next few weeks still chaos, but i have several Holden V8's lined up for assembly, so i will do all measurements required on one of these engines.
Craig.
#40
_SS Hatchback_
Posted 28 June 2007 - 11:24 PM
#41
_Toranamuk_
Posted 29 June 2007 - 01:02 AM
I WILL post up some pics & measurements very soon.
I've had a very very busy month & July is almost as busy already.
I have customers breaking my balls for jobs to be completed, so whilst i am building one of the 308's i willl finish the measurements & take pictures.
Craig.
#42
_SS Hatchback_
Posted 30 June 2007 - 07:57 PM
#43
_SS Hatchback_
Posted 22 January 2008 - 10:23 PM
#44
_Toranamuk_
Posted 30 January 2008 - 12:16 AM
Feb is out due to a full racing month, so I'll do it in March for you.
Craig.
#45
_lx-304_
Posted 27 February 2008 - 07:51 PM
when i changed from hq to lx,for some reason it moved centre of t700 10mm off centre,givig me more room for shifter and cables.if you put 2lx mounts back to back ie no block in the middle,they are symetrical.if you put 2 hq mounts back to back, you notice p-side mount is forward.this means when you put it on the front end and the mounts on sub frame are same distance from firewall,the rear of gearbox is moved across.has anyone else noticed this or am i going crazyDoes it actually move it further forward with hq mounts or not?
#46
_CHOPPER_
Posted 28 February 2008 - 11:31 AM
#47
_lx-304_
Posted 28 February 2008 - 02:27 PM
#48
_CHOPPER_
Posted 28 February 2008 - 03:23 PM
Something just didn't look right.
#49
_SS Hatchback_
Posted 26 June 2008 - 10:58 PM
#50
_LXEFI-8_
Posted 29 July 2008 - 07:35 PM
