Window tint
4 replies to this topic
#1 _lxhatch_jim_
_lxhatch_jim_
Posted 06 January 2006 - 09:31 AM
Hi lads. Any suggestions for how to remove the sticky residue that gets left behind when you remove the actual tint film. Hard scubbing works but I'm after a quick fix
#2 J-Rod
J-Rod
  • 189 posts
Posted 06 January 2006 - 09:35 AM
a rag and some acetone should do the job.
#3 LS1LX
LS1LX
  • 1,931 posts
Posted 06 January 2006 - 10:11 AM
get window cleaner, spray it on liberally and get a new razor blade and it will come right off, just dont scratch the glass.
#4 _Jewboy_
_Jewboy_
Posted 06 January 2006 - 10:21 AM
Wax & grease remover or Prepsol these should get the adhesive off fairly easliy after you scrap the film off. Best to use a spray bottle as it soaks in better than on a rag.
#5 davelh
davelh
  • 818 posts
  • Car:74 LH SL
Posted 06 January 2006 - 04:32 PM
I used to be a tinter and we used to use a soap and water solution and a 1 inch scraper blade to remove the tint and glue in one shot.
I would suggest using a steam gun to take it off the back window ( with a demister) otherwise you wont have a demister - No demister No problems scrape awy
One word of warning, if its on the torana the glass may scratch once some resistance is felt on the blade - CHANGE THE BLADE
also dont buy cheap blades OLFA or SNAP ON, although expensive are much better if you want a good, easy job
dave
