Lights getting bright then dim
#1 _mike_nofx_
Posted 06 January 2006 - 11:37 AM
Also, during the day with out lights on (prob happens with lights on too, havent noticed) my electricity gauge (battery meter?) is all over the place, sometimes it will sit in the middle... then ill look a few mins later and its all the way up, then a few mins after that its all the way down. the gauge doesnt move fast, just every few mins when i check it... its moved.
Car is an LX with SLR dash.
#2 _J&S Racing_
Posted 06 January 2006 - 12:29 PM
Maybe a loose fan belt, check alternator & what it's charging at.
#3 _devilsadvocate_
Posted 06 January 2006 - 01:05 PM
Check battery to body earth and also regulator is screwed in tight.
If okay, sounds like your regulator is being tempermental which would warrant replacement. Do check that the voltage readings you see on the dash are replicated at the battery by another voltmeter.
#4 _Yella SLuR_
Posted 06 January 2006 - 01:18 PM
Posted 06 January 2006 - 04:28 PM
i had this happen about 3 years ago and it kept popping my lights until i figured it out
dave
#6 _dazzaslr308_
Posted 11 January 2006 - 10:55 PM
#7 _mike_nofx_
Posted 16 January 2006 - 06:29 PM
#8 _dazzaslr308_
Posted 16 January 2006 - 10:41 PM
#9 _Yella SLuR_
Posted 16 January 2006 - 10:43 PM
#10 _devilsadvocate_
Posted 25 January 2006 - 09:02 AM
Ive done it on a few other cars but never my torries, the time has come for one of them. The original regulator is in place, it ends in 001, and is soldered on via a very short lead. The parts place said this reg was no longer available and gave me a reg ending in 005 which looks exactly the same except there is a ridge where a female spade connection can be made and solder holes if you want to go that way.
Do I solder the new reg in, or find the appropriate female spade connector that slides on? It looks like this wire has to keep very close to the fitting or it will foul other bits inside the alternator, so just not any female spade connector will do, can the right type of one be purchased.
Id prefer not to solder the new one in, looks like one would need a very hot/big iron to do it properly?, as well as having to awkwardly do this with very little lead to play with while leaning over the fender would be a pain, as would removing the alternator/aircon bracket to get the alternator off. However, i realise the original one will need to be unsoldered to start with, rather than cutting the wire, just so there is enough wire left to attach it.
Must be a lot of you out there that have had to deal with this, all suggestions welcome.
Thanks.
#11 _Yella SLuR_
Posted 25 January 2006 - 10:16 AM
Devils, what alternator do the UC's have? The books often talk about Lucas alternators but to tell you the truth, never seen one on a torrie or know how they are different. From what your telling me, yours is different again.
It's normally a plain uninsulated spade connector. But rather than connecting onto a pin or blade, it slides on an angled bit (from memory towards the brushes part of the connector. Really hard to explain. Do you have a mate with a Torrie, HQ with a Bosche alternator that you can just unbolt the reg to see the connection? It is an odd connection, nearly as odd as those weird windscreen wiper assembly clips.
#12 _Yella SLuR_
Posted 25 January 2006 - 10:19 AM
#13 _devilsadvocate_
Posted 25 January 2006 - 11:43 AM
#14 _devilsadvocate_
Posted 25 January 2006 - 08:28 PM
