Power Steering
#226
Posted 16 March 2009 - 06:07 PM
Thanks Axistr.
#228
Posted 17 March 2009 - 08:59 PM
Cheers dudes,
Grant..
PS. Like the tiny "this item is not for street use" labels on some products, I don't think you'd be liable, so long as none of the mods performed failed.
#229
Posted 18 March 2009 - 07:40 PM
I didn't take any photo's of the internal mods I did on the rack or post them up on the forum not because I wanted to keep it a secret but I didn't whant someone to copy it and do it wrong, F**K it up and cause an accident, we are playing with steering here not just putting on some mirrors or fitting shift lights. Sorry if I sound a bit harsh but this is reality, in this day and age someone allways want's to sue you.
Axistr
#230
_Squarepants_
Posted 18 March 2009 - 08:24 PM
You gotta look after no. 1 first.
Still, I want what you've done...
#231
_Lhover_
Posted 18 March 2009 - 09:59 PM
Cheers Chuck
#232
Posted 19 March 2009 - 06:56 PM
Still lots to think about but I am trying to sort thing out to keep everybody happy.
Axistr
#233
Posted 19 March 2009 - 07:56 PM
i'd have to install it and then get it engineered.
if i then crashed, and the steering had something to do with it
the spotlight would surely be on the engineer for approving an unsafe modification
and if i didn't get it engineered then i'd be to blame for having an illegally modified car?
or is that a to logical way of looking at it
#234
_dapperUC_
Posted 20 March 2009 - 12:55 AM
At this point you need to then submit your proposed vehicle modification to your local registration board (ie RTA, Vic Roads, etc) for approval to carry out the modifications
You then carry out the modification as per the engineers requirements which at the end of it he has to sign off on the modification
After this the car then needs to be presented to the registration board they do another inspection and hopefully sign off on it
Some registration boards want to see the modification in progress so you have to take note of there conditions if they include any, and all states are different i have known of engineered chassis kits being failed by the registration board so its essential that you get there approval and keep them on side as they have the ultimate power of the pen
On the kits my understanding is if you supply the kit only with a Certification certificate then the person fitting the kit has to get it approved as you have for filled your duty of care, its up to the buyer or the person modifying the vehicle to ensure it meets that states vehicle requirements. Wouldn't your engineer now ways to limit your legal exposure as they are usually well versed in their legal responsibility.
One thing that Axistr has brought up is the legal profession can really go for your throat if a mechanic carries out modifications especially if you have a roadworthy certificate under the prevision that you know better, i have had the police come in and shut us down until we proved we where in the right and its not a good feeling
#235
Posted 31 March 2009 - 06:11 PM
P.S Car and power steering going great and have clocked up around seven hundred km in it so far.
AXISTR
#236
_CHOPPER_
Posted 01 April 2009 - 10:25 AM
#237
Posted 09 April 2009 - 10:14 PM
Grant..
#238
Posted 15 April 2009 - 09:09 PM
How ever just to put some very rough figures together. rack $250.00, reco rack $290.00, rack mod $500.00, steering column adaptor $350.00 est.
supply brackets and cradle mounted to bolt directly onto subframe $450.00 (plus engineers report no cost at this stage)
Note; fitting or power steering pump bracket belts or hoses not included.
To fit the rack only and wheel align vehicle est 4 1/2- 5 hours but is car dependent.
as the torana is over 30 years old now you just don't know what problems you might come up against, bent or worn out parts, extractor clearance ect, ect.
it shits me at work when I give someone an est for repairs on thier car or truck and when we strip it down we find the problem is far worse then the expected, I ring the customer and advise of the extra work or parts needed and he yells down the phone telling me we will have to do the job at the same price and it's my fault, derrr that's why we give estimats because my x-ray vission is not as good as it used to be and the old crystall ball is broken and no one will FU**ING repair it. Sorry about the bitch session there but I will not give quotes that I carn't see through the phone line. ah I feel better now.
Wow it adds up quick.
Axistr.
#239
Posted 15 April 2009 - 09:37 PM
All in all great stuff, hope the conversion is still performing well in your car too.
#240
_Lhover_
Posted 15 April 2009 - 11:10 PM
#241
Posted 16 April 2009 - 08:35 PM
I just don't get it, what are these dick heads thinking of, get it wrong and cut corners it could cost your car or life.
I'am glad you think the price is good value, believe me there is heaps of work involved and I spent around 300 hours sorting mine out plus parts, add that one up in dollar value.
Lhover, I have done around 1,200 km so far and the hatch is driving excellent. I'am running 245x14" on the steer and have no tram tracking or bump steer what so ever, better than expected. As said previously I would like to give it a bit more caster but because of extractor to control arm mount clearance this is not possible on my car with out changing to UC control arms. The steering gives good feed back but I only have around 3/4 deg positive caster, with 3-4 deg it would give slightly more of a heavy feeling that I like. Don't get me wrong it's not too light it's just that I like that heavy weighted feeling that you get in the mercs, beamers and VE commodore's. It's like driving a vn or vs commodore power steering. I have changed the alignment setting twice now to see what effect it has on the handeling and will change it again in the next few weeks and play around just to see what happens. Steering is very direct and the rack is variable ratio so it is great on the freeway.
Axistr.
#242
_Squarepants_
Posted 16 April 2009 - 11:41 PM
Obviously you can't charge 300 hours worth of labour for each kit you may be supplying in the future but you have to recoup your costs within a reasonable time frame and then obviously make some sort of profit for your time and effort in creating a unique product.
What you've done is a remarkable acheivement so don't let anyone short change you with it. You'll make a lot of money out of this, I reckon, and it will be well deserved.
#243
Posted 17 April 2009 - 07:25 AM
I guess some people don't think its very cheap when they compare to other vehicles with factory power steering options that are simple to convert. 10 pages of this thread shows that a Torana is not so simple.
#244
Posted 17 April 2009 - 08:24 AM
You put in the hard work and 3.8k is reasonable concidering that is drive away. Also concidering all your hard work that you have put into it.
Good to hear that it is still driving well for you.
Keep us updated if you start producing the brackets and parts for purchase to do this conversion.
Evan.
Edited by Evan, 17 April 2009 - 08:25 AM.
#245
Posted 17 April 2009 - 12:51 PM
You may want to talk to someone about registering your design though, as has been said, we don't want anyone cutting the heads off your daisies!!
Grant..
#246
Posted 17 April 2009 - 09:04 PM
Axistr
Len
#247
Posted 17 April 2009 - 09:11 PM
I attended an XF Falcon today and you could flick the steering gently with one finger, let go of the wheel, and the wheel would power steer it's self to lock.
Then you could gently flick the wheel the other way, let go of the wheel, and again it would power steer to the other lock.
The car was stationary.
Would this be a control valve issue in the box?
#248
Posted 17 April 2009 - 09:40 PM
Axistr
#249
Posted 17 April 2009 - 09:51 PM
You mean the twisty reaction plate thingo on the shaft inside the box?
That's what I thought and related to the member.
The member thought the steering was broken till I pointed out that the wheels were actually turning.
He drove the car last night, parked it in the driveway and it was like this when he went to drive it this morning.
I've never experienced this fault with P/S in 35yrs.
Edited by rodomo, 17 April 2009 - 09:54 PM.
#250
_CHOPPER_
Posted 17 April 2009 - 11:44 PM
