Rubber Bush avalibility
#26 _73LJWhiteSL_
Posted 18 March 2007 - 01:49 PM
Do you have the part numbers for ball joints, and the caster/control rod to crossmember bushes?
Steve
#27
Posted 18 March 2007 - 01:58 PM
BJ 55 for lower ball joints
Strut rod bushes in Nolothane 48009 about $45
#28
Posted 19 March 2007 - 10:25 AM
#29 _JBird_
Posted 19 March 2007 - 02:00 PM
Yet to find out how it rides, haven't had the time to work on car yet.
#30 _crumpledoor_
Posted 19 March 2007 - 10:52 PM
Upper Kit (4Pce) - 38.58
Lower Kit (4Pce) - 72.26
They have the ball joints and tie rods as well. Not too badly priced. Roughly about the same I paid 12 years ago.
Good luck, GO THE TORRIES!!!
#31 _BCR42Y_
Posted 08 April 2012 - 11:46 PM
The GMH part number for lower control arm bushes and lower trailing arm bushes was 2807098, superceeded by 9942588. (as per Dattomans above post).
The current Mackay Part number is - A1121
The current Kelpro part number is - 25008, however Kelpro also list a 25007 for the "front control arm - lower inner front" and looking at the picture it looks as though the outer shell is a bit shorter and has three round balls on the end of it? Is this for RTS models only? Is there any benefit of using them over the A1121/25008?
I note there was discussion about the centre tube being rolled or a dedicated tube, how much effect would this have?
Of the two manufacturers which would you buy?
Sorry for all the questions, I have been burnt by replacing a perfectly good set of rubber bushes with the blue brand that is no longer around only to find they have perished in a couple of years and with less that 2000kms on them.
I don't want to have to change the bushes again anytime soon, so want to be sure I get a good product.
#32
Posted 09 April 2012 - 12:00 AM
Inside the bags were McKay bushes marked A1121 and A1119
And I'll be fitting them to the SS when the time comes
#33 _BCR42Y_
Posted 09 April 2012 - 12:16 AM
As always thanks again for your quick reply and advice.
I will be going with Mackay bushes.
Edited by BCR42Y, 09 April 2012 - 12:17 AM.
#34 _LH SLR 3300_
Posted 09 April 2012 - 07:37 AM
#35
Posted 09 April 2012 - 08:04 AM
good topic to bring up,
as always very informative and well researched ,plus tried and proven
Can you please list brand and part numbers to rebuild front end.
thanks
#36 _BCR42Y_
Posted 09 April 2012 - 09:37 PM
Thanks for the reply, sorry to hear you have gone through this also.
Did you end up using the Mackay rubbers in the rear trailing arms?
Halil.
#37 _BCR42Y_
Posted 09 April 2012 - 09:40 PM
I am going to use Mackay rubber products for the front and rear, the numbers of the parts from my research are:
Front lower control arms and rear trailing arms - A1121 (A1202 is listed for "control arm lower bush front heavy duty (With RTS)"
Front upper control arms - A1119
Cross Member to body Kit from Rare Spares - FEK9
Moog Ball Joints - K5103 Lower, K5108 Upper (Rockauto)
Tie Rod Ends - Still researching / looking for suggestions.
Steering rack bushes - Still researching / looking for suggestions (Haven't been able to locate any info on a rubber product being available).
Halil.
