![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
UC Torana 350 Chev
#176
_UC_CHEV_
Posted 01 June 2007 - 12:29 PM
#177
_Lamo_
Posted 01 June 2007 - 03:42 PM
Really?broom broom!
any audio?
![:D](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/biggrin.gif)
#178
_MRNOS_
Posted 01 June 2007 - 03:55 PM
If thats how the new engine sounds, I think you have a problembroom broom!
![:tease:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/tease.gif)
#179
_TJ253_
Posted 01 June 2007 - 03:57 PM
#180
_UC_CHEV_
Posted 01 June 2007 - 04:01 PM
oil pressure was primed, then it decided to not have any preasure for 8minits of running in... most bottom parts will be destroyed.
gonna go cry now.
#181
_TJ253_
Posted 01 June 2007 - 04:06 PM
#182
Posted 01 June 2007 - 04:36 PM
#183
_MRNOS_
Posted 01 June 2007 - 05:00 PM
#184
_LX406_
Posted 01 June 2007 - 05:52 PM
Thats what I was thinking.....Umm maybe a stupid question but why was it left to run with no oil pressure for 8minutes?
#185
_SLR Goat_
Posted 01 June 2007 - 11:15 PM
Edited by SLR Goat, 01 June 2007 - 11:17 PM.
#186
_LX_SS_
Posted 02 June 2007 - 12:58 AM
#187
_TJ253_
Posted 02 June 2007 - 01:03 AM
#188
_Keithy's_UC_
Posted 02 June 2007 - 07:00 PM
I really hope things turn out for the better and your bottom end is ok. Thats no good man - i'm sad for you...
Keith
#189
Posted 03 June 2007 - 08:40 AM
#190
_DocDamage_
Posted 03 June 2007 - 09:43 AM
Russell
#191
Posted 03 June 2007 - 08:14 PM
#192
_[BOTTLEDUP]_
Posted 05 June 2007 - 12:59 PM
#193
_Keithy's_UC_
Posted 05 June 2007 - 07:16 PM
I'll hopefully be there for Powercruise this year, i'll stop in and check it out then!!
Good luck man, i hope there's no damage to the motor.
Keith
#194
_UC_CHEV_
Posted 03 July 2007 - 10:40 PM
took a few weeks to get over my engine not running right
![:cry:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/crybaby.gif)
found some missing oil gallery plugs which caused the low oil pressure, if anyone was curious. glad to have found the problem
![:rockon:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/rockernana.gif)
got off pretty light, just a crank journal linish and polish and all new bearings.
started to rebuild the motor. crank, rods and pistons are all in. should have zero problems this time
,nathan
#195
_Lostit_
Posted 04 July 2007 - 09:47 AM
Question UC you did prime the pump before start up ? Should of showed like 20+ psi at least on prime
#196
_UC_CHEV_
Posted 04 July 2007 - 01:34 PM
beginners mistake
oil pick up was still perfect
![:spoton:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/spoton.gif)
#197
_[BOTTLEDUP]_
Posted 04 July 2007 - 01:50 PM
![;)](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/wink.gif)
#198
_SLR Goat_
Posted 04 July 2007 - 04:11 PM
#199
_UC_CHEV_
Posted 04 July 2007 - 05:13 PM
come over and drink beer
Edited by UC_CHEV, 04 July 2007 - 05:14 PM.
#200
_Lostit_
Posted 04 July 2007 - 09:51 PM
I know when i got mine done they put a inertia gas inside the pickup to stop the heat flaking pieces on metal inside ..if you get what i mean . WOuld like to see you going to all this to get the oil pump jamming or clogging up .
Yeah should hook up a gauge( MAster gauge ) on the oil sender and see what psi you get on priming. ANd im not sure what you mean by priming but i prime with using a proper tool but you attach a pistol drill to ... with the dizzy removed and prime the engine before cranking it over.I know i got up to 30psi with the drill .
SOrry if im asking silly questions just trying to be helpful.
