Difference between LX RTS & UC RTS ???
197 replies to this topic
#176 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 20 April 2013 - 11:12 AM
Yes ^^^  that is simpler because to swap the rack over your gonna have to decouple the steering shaft anyway and to swap the upper control
arms your gonna have to unbolt and semi detach the K-frame as well to get the arms over to tower.
Plus with UC K frame you will also get the advantage of the heat shield cover for the steering flexi coupling.
Swap the whole lot.
Edited by fuzzypumper, 20 April 2013 - 11:14 AM.
#177 _LH8VD69_
_LH8VD69_
Posted 20 April 2013 - 06:35 PM
Ok so I'm not being clear enough. Sorry guys. I am removing my whole LH K frame including power steering and want to bolt the whole 1980 UC K frame including manual steering in my LH. Question: What do I need to do to the UC front end to make it geometrically better? Red drill the mounting position of the UCA?
Datto perhaps move all this to its own place as its getting off track from the sticky.
#178 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 20 April 2013 - 06:51 PM
Do nothing
If you are confident it's unmolested.
Bolt the complete 1980 k frame in
Add new coils and shocks
Get a quality wheel alignment
Enjoy
#179 _LH8VD69_
_LH8VD69_
Posted 20 April 2013 - 06:56 PM
Do nothing
Enjoy
Ah kool ! It's totally unmolested with only 160k on it with a starfire engine in it. What's all the talk of redrilling the UCA mounting positions lower then?
#180 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 20 April 2013 - 07:38 PM
All the talk is changing LH and non A9X LX UCA positions to replicate A9X or LX RTS positions
As yours is an 80's UC , we can safely presume you have the latest in RTS geometry.
So bolt in and enjoy
#181 76lxhatch
  • 7,222 posts
Posted 21 April 2013 - 07:11 AM
You could still re-drill them if you wanted, it does provide a little improvement in camber gain during suspension bump. Based on my own measurements it doesn't have any significant ill effects on bump steer so safe enough to do. However its not probably not something you'll really notice driving it down the street so you could just as easily leave it as-is.
#182 _LH8VD69_
_LH8VD69_
Posted 23 April 2013 - 12:24 AM
Thanks ! It's just the K frame / suspension isn't in the car as yet so if there is a little mod to help best do it while its out. How far down would u recommend the new holes be drilled? 35mm
#183 76lxhatch
  • 7,222 posts
Posted 23 April 2013 - 05:19 AM
Probably not quite that much, closer to 25mm; you can't really get it wrong if you use the upper arm pivot to mark it. It should sit at the lowest point while still remaining flat against the cross member and allowing space for the shims to sit flat in between them. Make sure you don't change the angle between front and rear holes, i.e. they should be an equal distance lower than the originals.
#184 _LXproject@50_
_LXproject@50_
Posted 14 December 2014 - 08:54 PM
HI gents ,
Just been working on my project LX, just fitting a WB rear disc 10 bolt, bought the whiteline upper arms and had to put two bends and reweld to make them align. just got a hold of WB stub axle and brake for the front also (bigger brakes all round) picked up a new WB master cylinder with the proportioning value in it, had to re drill the firewall to level out the master as the WB has an angled mount holes.
Just about to jump into the whole UC upper arm thing myself, I may have a pair to remove this weekend if I am lucky, I will take the measurements and check where the upper mount holes are drilled, my first car was a LH in 1979 and it scrubbed tyres but lots of U turns back in the day.
Also picked up a TF power steering rack and turned the power head 180 degrees as the head appears to be non directional and just had new pipes made up to suit the new positions which leaves with one big question to those who have used the TF powersteering rack before - what was your solution for the tie rod ends being different threads ?
#185 Ando
Ando
  • 527 posts
  • Car:6/'76 L32 SS white & black. 9/'76 L31 SS gold. 5/'77 L31 SS Chamois. 3/'79 UC SL Deluxe hatch.
Posted 24 March 2015 - 01:16 PM
Without going through the whole thread again.. I have all the parts to either build an A9X front end suspension design or I could restore a UC RTS front end.. The two sets of wheel combo's I can run will have 285 40 15 Yoko's on 81/2 Simmons & 91/2 Hotwire front rims.. They will work on either front end set-up.. I'm building the car for mainly street & some circle track fun so still a little undecided which front end geometry design is best for my application.. Any thoughts welcomed..
#186 Bigfella237
Posted 24 March 2015 - 05:17 PM
As I recall, the only differences between the A9X and UC front suspension are:
1. the location of the UCA pivot point
2. the stub axles
3. the steering arms
4. the bump stops
No 1 can be changed by re-drilling the holes in the K-member, earlier in this thread it was stated that lowering the mounting point will slightly improve the camber curve and bump steer on suspension dive, but the biggest affect it will have is to dramatically lower the front roll centre, which is not necessarily a good thing unless you're also able to lower the car's centre of gravity (which drop spindles will help with) or mass, or preferably both. The farther the distance between the RS and CG, the greater 'leverage' the mass will have as the CG changes, in layman's terms, the more body roll you will have.
Stub axles are another compromise because of the lower included angle designed into A9X/Hx stubs (the included angle accounts for most of your KPI together with static camber), the lower the KPI the greater the scrub radius, which is most likely terrible already if your rims have a negative (outward) offset. The best option here would be a hybrid stub axle which retains the Torana stub's included angle but raises the spindles like an A9X and suits the A9X/Hx brakes (bigger wheel bearings would be a bonus too).
The steering arms need to match the UCA / stub axle combo, if using A9X/UC UCAs then you would either use the UC steering arms with the UC Torana stub axle, or the A9X (Harrop) steering arms if using the Hx stub axle.
The compression bump stops I believe were extended on the A9X because of the bigger diameter wheels and drop spindles.
So basically everything is a compromise, the brake setup you want to use may dictate the stub axle you have to use, which will also dictate which steering arms you use, but if it was a question of paying Harrop the big bucks to run the A9X stubs, or having the lower scrub radius of the Torana stubs, I know which one I choose, then I'd put the money you saved on the Harrop arms toward a Hoppers brake kit (which suits the Torana stubs).
But that's just me...
#187 Ando
Ando
  • 527 posts
Posted 25 March 2015 - 07:41 PM
Thanks Andrew.. Great read.. I think what confused me in the past was the lx rts which I'm dismissing altogether..
I have mocked up my steering & front brake options..
The first 2 pics are the a9x/hx 1 ton stubs, harrop steering arms, 4 piston wilwood calipers 11" rotor & uc upper control arms..
2nd pics are the torana stubs, uc steering arms, same wilwood brakes, & uc upper control arms..
So it really come down to which is more suitable for my application & regarding roll centre, scrub radius, wheel offset, tyre width etc..
I will be running 285 40 15 tyres on the front on both sets of wheels.. 91/2 hotwires - 125mm backspace & 81/2" simmons - 120mm backspace..
I will be installing power steering so no problems turning these tyres lol but I need to decide which will be better without really knowing at this point..
So which way?? Yes I know I'm spoilt for choice lol
#188 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 25 March 2015 - 08:24 PM
Go the Tonner stubs, copy the A9X setup with top control arms lowered and Harrop steering arms.  Use the UC top control arms.  Especially if you already have these bits.
As you can see, far more top balljoint room to the rim.
It gives slightly better geometry going the A9X setup as it raises the front roll centre when you lower the top arm mounts (you want this in a torana) and improves the camber curve and helps with front tire wear on the outside edges.
Watch your static camber if you are lowering the car in the front, you may run into trouble getting back under -1 degree.
The scrub radius will be what ever it will be with each setup, but if you have the wheels legal offset and under a set of A9X flares, it will be fine.
Check with your engineer, they may let you go wider offset on the front with the H series stubs.
#189 Bigfella237
Posted 25 March 2015 - 11:53 PM
~ 91/2 hotwires - 125mm backspace ~
Great photos Ando, that really illustrates some of the clearance issues.
So it looks like a 125mm backspace is just about the maximum possible for a front wheel regardless of the overall width, with 15" rims at least, you might be able to squeeze a few extra millimetres with a larger diameter rim as it would give a little more wiggle room around that top ball joint?
I don't suppose anyone you know has a 17" or 18" rim you could try on with roughly the same backspace, I'd love to see photos of how much difference a larger diameter rim would actually make?
~ it raises the front roll centre when you lower the top arm mounts ~
You had me thinking M@ as I'd previously stated the exact opposite, but you are correct...
Attached File  Roll-Center-with-Lines.jpg   75.03K   6 downloads
So lowering the UCA pivots raises the RC; and
extended upper ball joints would also raise the RC; and
extended lower ball joints would raise the roll centre as well as raising the spindle height (lowering the car)?
Attached File  Roll-Center-in-Dive-with-Li.jpg   79.9K   6 downloads
#190 axistr
axistr
  • 1,224 posts
Posted 26 March 2015 - 09:58 AM
I agree with all of the above. But the higher the KPI the better the return to centre is and better the scrub radius especially with wider rims with negative offset. Higher KPI and more positive caster is the go, combined with the top control arms in the lower position to give a better camber angles through hard cornering. For every day driving either the UC or A9X set up is ok so long as its set up correctly
But going back to basics you can have the perfect set up and the wheel alignment can let you down every time. And remember the back end alignment is just as important as the front. I can easy spend 4 hours wheel aligning bad handling cars and the outcome can be astonishing to say the least. As I have said before sometimes its as simple as tyre pressures and or bad choice of rims & tyres.
Torana's also respond well to good adjustable shocks and heavy duty springs without going to firm, the more they float around the more input you need to control them. If we were designing a new Torana front end steering geometry from scratch it would be an entirely different situation, so basically we have to make compromises.
#191 Bigfella237
Posted 26 March 2015 - 12:04 PM
Forgive me if this has been asked before, but seeing as we share the same upper and lower ball joints as a lot of early Chevy stuff (Camaros etc.), has anyone looked at getting a pair of custom stub axles out of the US?
A quick google shows a huge range available and the most expensive I've found so far was around US$300 for a pair, heaps of different drop height options too but nobody seems to mention the included angle?
#192 yel327
  • 13,785 posts
Ando, have you looked at the SCW (Southern Chassis Works) complete crossmembers with brakes, power steering rack etc? I'm going to invest in one for one of my HK's.
#193 Bigfella237
Posted 26 March 2015 - 12:17 PM
Southern Chassis Works has now been owned and operated by Curley’s Rods & Customs for the last year, In that time we believe our IFS front end units have become the best on the market.
Starting at just $4500 for complete IFS units with man rack, brakes and adjustable QA1 shocks
http://www.curleys.com.au/
http://www.curleys.c...uthern-chassis/
Also see this thread: http://www.gmh-toran...ifs-front-ends/
#194 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 March 2015 - 09:17 PM
I'm watching closely how you go with 285's under the front, What tire size are you going to use?
I am about to embark on getting 275's to fit mine so I hope to learn a trick or 2.
Matt
#195 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 26 March 2015 - 09:21 PM
I reckon you may need steering stops like the UC has on the lower control arms too, so either copy them or use UC ones.
The Harrop steering arms don't have the lumps on the side so you may need to make the stop a little bigger.
#196 _LXSLR5000_
_LXSLR5000_
Posted 05 April 2016 - 03:11 PM
I think the jury is still out on that one Toranavista.
The only things I can suggest is they wanted to design more understeer back into the front end.
Either that or they considered the additional Castor they ran in the UC was sufficient for cornering and they didn't need the steeper camber curve.
We need one of the buggers who designed it to chip in with their reasons about now :tease:
I can't see a prob drilling the UC one lower and tearing around like that on the street - I actually plan to make twice that change on mine.
In fact I have been doing it for 3 1/2 years and I am one of the only ones I know with 255 tires up front that don't wear too badly on the inner and outer edges.
M@
Hi,
I know this is an old post, but I have just joined up. I'm upgrading the brakes/suspension and this is just the info I need.
The only thing is I can't see these photos which I think would be of great help to me. Any idea why I can't?
Scott
#197 StephenSLR
StephenSLR
  • 6,717 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 06 April 2016 - 09:03 AM
As you said, it's an old thread. What happened was the original posters put up the pics on Photobucket and either deleted the pics to make room for more, no longer have a Photobucket account or perhaps the photos expired on Photobucket. I found this out once when I hadn't logged in to Photobucket for a long time and when I logged back in the photo links regenerated and appeared again.
s
#198 _LXSLR5000_
_LXSLR5000_
Posted 06 April 2016 - 04:58 PM
s
OK. Thanks.
