hub size for lj & hq???
8 replies to this topic
#1 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 09 January 2006 - 04:37 PM
hi everyone
Just got myself a pair of hq dba undrilled sloted disc (dba 014usr & l) for my lj
Now iv taken the disc to get them drilled to lj patten and hes asked me to give him the hub size why is that????
Should't the disc just need to be drilled to lj patten and just bolted up to the hq stub???
danny......
#2 _CHOPPER_
_CHOPPER_
Posted 09 January 2006 - 04:39 PM
The hub is the part of the disc the centre of the rim is supposed to locate on. The hub diameter of an HQ is 71.5 MM. The Torana is smaller. Don't know the exact measurement off the top of my head.
#3 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 09 January 2006 - 04:55 PM
Ok i see but if iv ordered hq disc should't the hub size already be 71.5mm?????
thanks
danny.....
#4 _CHOPPER_
_CHOPPER_
Posted 09 January 2006 - 04:59 PM
They will be. They need to be machined down so the Torana rims will fit.
#5 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 09 January 2006 - 05:08 PM
OK so i need to find out the hub size for a lj so i can fit the lj rims on to the hq discs??
thanks once again :)
danny...
#6 dannygtrxu1
dannygtrxu1
  • 71 posts
Posted 09 January 2006 - 07:47 PM
A mate of mine has told me that the lj hub is 60mm
can someone plez confirm this for me....plllleeeaaasseee
danny....
#7 _CHOPPER_
_CHOPPER_
Posted 10 January 2006 - 05:35 PM
I have an LH hub and a set of vernier calipers. I can mearsure that later. Should be the same, but it may not be.
#8 dattoman
  • 16,485 posts
Posted 10 January 2006 - 05:49 PM
Can't you just take your wheel to the machinist so he can measure the centre board of your wheel ?
#9 _CHOPPER_
_CHOPPER_
Posted 10 January 2006 - 05:53 PM
Not all alloy wheels have the centre bore machined to the exact hub size. So if the centre bore of these rims have a measurement larger than what the LJ hub is, then other rims he may use in the future may not fit.
