Henrob Welder
Posted 06 March 2007 - 08:42 PM
Just was enquiring about the Henrob, I was quoted $999 for the welding kit, tips etc, full face mask, and European regulators etc and deliver to sydney, all brand new of course, is this a reasonable price to pay??
Also any comments on this welder would be great, i want to learn to weld aluminium in particular.
Kind regards
Bart
Posted 06 March 2007 - 09:09 PM
are they korean/taiwanese?
it must be ac output for aluminium.
Posted 06 March 2007 - 09:29 PM
Posted 06 March 2007 - 09:42 PM
the 999 dollars would be better spent on a B.O.C inverter and tig set to go with it.
you wont be able to do ally though. that will cost significantly more.
Posted 06 March 2007 - 10:16 PM
p.s. my mig is reverseable so it welds alloy.
Posted 06 March 2007 - 11:00 PM
Ill check out ebay
Posted 06 March 2007 - 11:01 PM
was that with regulators as i believe the regs are expensiveHenrob has also been sold under the Dillon brand in the past. These units occasionally come up on EBay way less than the new price you have been quoted. The biggest difference between the Henrob and a typical oxy like a CIG Comet is in the low pressure regulators which come with the Henrob. With MIG welders now so popular an oxy can be picked up for virtually nothing. Aluminium can be welded with an oxy unit and l would not be in a hurry to by a new Henrob at that price. l believe that regulators can be modified for low pressure operation which will give performance like a Henrob, but you will then need another set of regs for cutting.
Posted 06 March 2007 - 11:32 PM
yes, it probably would be if you chasing those neat alloy welds, but I'd probably lean towards tig if you got enough jobs to warrant it.I thought of an oxy but was lead to believe the Henrob is superior in welding aluminium.
Ill check out ebay
Never used the Henrob and never seen a work shop with one, might be something in that.
Posted 06 March 2007 - 11:41 PM
No-one ever used it cause they didn't know how
Think it went in the bin
Posted 06 March 2007 - 11:44 PM
Panel beaters, vintage car builders, street neat rod and custom love them as they say.yes, it probably would be if you chasing those neat alloy welds, but I'd probably lean towards tig if you got enough jobs to warrant it.I thought of an oxy but was lead to believe the Henrob is superior in welding aluminium.
Ill check out ebay
If you check out streetneat you can see them using it.
Posted 07 March 2007 - 05:36 AM
Posted 07 March 2007 - 08:31 AM
pressure is adjustable on normal guages.
Posted 07 March 2007 - 08:45 PM
Spoke to the guy at streetbeat (i told him about this forum) he said the Henrob is great basically as it causes less warpage in the panel, can weld aluminium very nicley, as good looking as TIG welds and as strong, will do mild steel and stainless, all looking as good as TIG and just as strong. He even welded a cast manifold using a piston ring as a filler. He basically highly recomends it.
Price wise, he suggested around $900 is the going rate with regs, hand piece and tips etc
He recomended using flux on the job and rod in welding cast alloy, and flux just on the job when welding aluminium, the flux is a specific type which can be bought anywhere, but i should ask the seller of this item which type of flux, if i remember rightly flux for aluminium and alloy is different.
Edited by Bart, 07 March 2007 - 08:50 PM.
Posted 07 March 2007 - 09:43 PM
just trying to help out with your mission. might save a quid.
_Pete_
Posted 07 March 2007 - 10:28 PM
Not too many workshops do much oxy welding these days, only restoration shops really.
If you enjoy Oxy welding and have a real passion for it then I think you'd enjoy a henrob torch and get great value out of it. For most of us at home a MIG will handle most car stuff, oxy only really gets brought out for heating stuff.
Posted 07 March 2007 - 11:00 PM
Posted 08 March 2007 - 05:49 AM
Posted 08 March 2007 - 12:21 PM
for CAST alloy i'm not so sure ( not a welding expert), but we bought a 220A single phase MIG welder with a second torch set up for aluminium welding. Cost us a bit but we've got a very versatile unit now that will weld most stuff!
_Pete_
Posted 08 March 2007 - 01:34 PM
#21
Posted 08 March 2007 - 09:56 PM
The regular price for a welder is arounf $70 an hour and i have that fuel tank i started making 3 years ago need to be welded, then theres the bell housing, it will end up over a grand i estimate at $70 an hour, so buying a Henrob would be worth my while, a TIG would be really nice but like i said far too expensive for me.
#22
Posted 08 March 2007 - 10:10 PM
Nice info Pete thanks.This discussion here may help you out with a bit of info....
henrob VS tig
I think the greatest incentive for me is the price of the Henrob. Im going to go for it.
#23
Posted 09 March 2007 - 11:28 AM
Posted 10 March 2007 - 09:44 PM
#25
Posted 11 March 2007 - 09:59 AM
Monaro is going very well however! Been driving it around a fair amount and it's great! Got lot of other stuff happening at the moment, so i'm not able to give it the finishing touches it deserves!
Cheers mate, Hope to catch you soon! You coming out on the 31/3? Take a look in the events section!
