FORD POWERED TORANA
#51
_scottya!_
Posted 26 March 2007 - 09:15 PM
#52
_scottya!_
Posted 03 April 2007 - 09:40 PM
Had to buy new digi camera so i could get some pics together to post.
Been expeirmenting with photobucket so , see how we go hey !
Just a few pics of wheels, gearbox crossmember, modified front sub
frame compliments of GONZO'S exhaust here in brisbane and 3 inch
mandrel bend dual exhaust with hooker aero chamber mufflers and 3
GONZO'S resignators. Picture is of car that i have to dummy assemble
all my parts back into to have extractors remade(time consuming).
#53
_scottya!_
Posted 31 December 2007 - 05:22 PM
Hopefully going to be doing the much avoided dummy assembly in
a few weeks so i can have the extractors remade. Done away with
the old 9 inch and upgraded to a sheet metal diff, better looking and
much straighter and stronger than standard 9 inch. also new to the
diff set up will be adjustable upper arms and up front i invested in a
set of hopper stoppers big brake with 4000 series slotted rotors
(there big and look awesome). The front k frame also got sandblasted,
rebushed and repainted ready to go in. Was originally going to put the
GTS rims on, but decided not to and bought a new set of weld draglites.
Look forward to reading your interesting comments
#54
_gtr-xu1_
Posted 31 December 2007 - 06:03 PM
gtr-xu1
#55
_scottya!_
Posted 31 December 2007 - 06:18 PM
as you do. But i will push along, as slow and steady normally wins
the race so they say. Got diff built up here in brissy . $1500.00
#56
_Barman_
Posted 31 December 2007 - 09:26 PM
I never even got this on the track(burnout) when i rapt it round a power pole (up my driveway) now this awsome engine is in a Datsun Sunny .
#57
_1BADSS_
Posted 01 January 2008 - 10:05 AM
BTW, I run a Ford 9" and the paint on the SS is a Ford colour.
#58
_scottya!_
Posted 01 January 2008 - 12:04 PM
A forum member (lakeside) expressed some interest in dropping
a windsor into a LC torana, dont know if he actually went a head with
it,but if anybody does know or even if lakeside reads this thread,lets
us all know. Would look the goods !
Maybe some-one should open a thread on engine swaps, would make
very interesting reading. I did read about a bloke wanting to put a 253
and trimatic in an XD ute some years ago. the artical was in street machine
in some tech dept from memory.
#59
_scottya!_
Posted 05 May 2008 - 03:01 PM
big brake kit mounted. Done away with engine mounts , now going to use engine plate so i can move engine back closer to fire wall.
Will post more pictures when extractors have been remade , engine plate mounts are complete and sheet metal 9 inch in place. Cheers
#60
Posted 05 May 2008 - 04:46 PM
Are you gonna keep the ford rocker covers?
#61
Posted 05 May 2008 - 07:58 PM
or 6 for that matter but i can appreciate the effort that is going into this if i was going anythign other than holden or chev in my cars itd be a mopar
#62
Posted 05 May 2008 - 08:01 PM
#63
Posted 05 May 2008 - 08:05 PM
yeah i'd go the mopar myself as well, but this looks like it's comin along well.not a fan but each to there own i personally would never own a ford v8
I saw an rx2 mazda with a mopar v8 at the drags on sat.
That was something different...
#64
_gen3torrie_
Posted 05 May 2008 - 11:09 PM
#65
Posted 06 May 2008 - 12:08 PM
#66
_scottya!_
Posted 06 May 2008 - 05:51 PM
#67
Posted 06 May 2008 - 07:55 PM
#68
_ucongas_
Posted 11 July 2008 - 01:44 AM
I'd hate to think of the same combo in a lightweight torrie..
Man you gotta have balls.
#69
Posted 11 July 2008 - 07:30 AM
#70
_UDLOSE_
Posted 11 July 2008 - 08:23 AM
C'mon it's not like he's painted the car pink or put chromies on it!!
If you like going fast "staying true to the general" is very expensive and in my opinion foolish, especially when your talking about early heads. If your building a replica or trying to beef up an original SLR etc then it's understandable. But when that doesn't apply, throw the entire driveline on ebay and start again. The torana diffs, gearboxes and tailshafts are no good, why stop at the engine?
I've got mates who are into fords and I've come to realise the clevo is a good peice of gear. Look at the size of the intake ports on those heads ffs!
Edited by UDLOSE, 11 July 2008 - 08:25 AM.
#71
_lx-304_
Posted 11 July 2008 - 08:59 AM
#72
_AGGRO_
Posted 11 July 2008 - 11:14 AM
#73
_scottya!_
Posted 11 July 2008 - 06:10 PM
Project coming along slowly as usual. Hit a snag the other day. Couldn't mount the shockies on top of the trailing arm brackets because of the brake callipers are in the way. So i invested in some coiled over shocks and i am mounting them in the car this weekend. I also decided to do a mini tub job and got some tubular lower trailing arms made up 1 inch longer than the standard trailing arm with adjustable heim joints top and bottom to adjust pinion angle. I'll take more photos and post after the weekend.
_scottya!_
Posted 14 July 2008 - 07:22 PM
put the diff back in, rehang the exhaust system again and weld the neccesary brackets to mount the QA1 coilover shocks.
not a real good picture of the exhaust system , will get a better picture when the car is up on the hoist.
dummy engine and box in engine bay with extractors bolted in place. Plenty of clearance.
just got to lower the back another, probably 1.5 inches so the guard sits halfway down the wall of the 28x9x15 M/T slick.
upper and lower adjustable trailing arms with hiem joints i got fabricated.
#75
Posted 15 July 2008 - 07:43 PM
You can trim the lip on each side of the chassis rails for a little more clearance if you wish, I did this on my old hatch when I fitted a 427 Chev into it many years ago and this gave me even greater room when changing plugs and so on.
Another one outside the square,I reckon an LC or LJ with a hot 265 and Webers would go like stink
