fabrication (MELB)
Posted 11 January 2006 - 08:07 AM
it will be 240mm in diameter and will need to be made from 2mm plate.
Can anybody recommend somewhere that would be able to do this ?
Posted 11 January 2006 - 08:52 AM
I'll ask one of the fitters here at work if you like...can't promise anything...extremely busy installing a new printing press atm.
Posted 11 January 2006 - 09:11 AM
The major cost with that is the setting up time, so if you only need one it could be a bit expensive. If you can give them that drawing with the size of the cut outs ( the steps), then it wouldnt take them so long to set their computers up to do the cut which would save you some! Depending on what it is.. it may pay you to get a second ( or more) cut at the same time too.. once theyve got it cutting its really only the matierial cost!
Posted 11 January 2006 - 09:25 AM
Thanks for the advice Tiny. I haven't calculated the widths of the slots yet. Once i do i should be able to get it drawn up in CAD.
This is the trigger for my crank angle sensor and will definelty be a one off. Running the chev v6 DFI system on a holden 6 isn't really common practice.
Posted 11 January 2006 - 09:30 AM
Sounds like your into a good conversion, best of luck.
#6 _dansedgli_
Posted 11 January 2006 - 09:45 AM
I have a similar disc for my RB30 that I got from my ECU supplier.
Posted 11 January 2006 - 10:01 AM
240mm Diameter!? thats a bloody big trigger plate! (24cm!)
Yeh.. a bit like bolting a dinner plate to your balancer.
at first i was turned off by it beacause i thought it would look stupid.. but it makes for the simplest mounting of the CAS. i have made an adjustable bracket that mounts the sensor off the two front sump bolts.
I still might investigate changing the sensor mount to reduce the size of the trigger.. i think its gonna look a bit rare at 240mm.
Posted 11 January 2006 - 10:25 AM
I wonder if there are any distributors that would fit the red 6 that would have the same chopper disc in them? That way you could use its signal as your CAS too.
Posted 11 January 2006 - 01:40 PM
That would be nice.. only trouble is i don't have room for a distributor.I wonder if there are any distributors that would fit the red 6 that would have the same chopper disc in them? That way you could use its signal as your CAS too.
i'll have my supercharger hanging off the drivers side of the block.
the only engines i know of that use this chopper wheel are the chev 60 degree v6, some lada vehicles and the isuzu v6 in early 90's jackaroos. I think that in all these aplications the trigger is actually part of the crank anyway.
Posted 11 January 2006 - 02:06 PM
No worries mate, sounds like youve though of it all already!
Cool mate Hope you get it sorted
#11 _Oldn64_
Posted 11 January 2006 - 07:14 PM
#12 _CHOPPER_
Posted 11 January 2006 - 07:16 PM
Posted 11 January 2006 - 08:12 PM
Decisions, decisions.. i've gotta get out there and do some more measuring!
#14 _CHOPPER_
Posted 11 January 2006 - 08:23 PM
Posted 11 January 2006 - 08:35 PM
Posted 11 January 2006 - 10:32 PM
RACV MAN
Posted 11 January 2006 - 10:52 PM
I have a set of VN chopper wheels and a VN CAS (twin hall effect) here.. to use these i would need to have a boss made to mount the chopper wheels out off the front of the crank.. a set of holes in the flywheel or a single flat disc bolted to the balancer would be much simpler.
#18 _Oldn64_
Posted 11 January 2006 - 11:05 PM
Posted 11 January 2006 - 11:21 PM
Total picture?
This has changed a little since i last posted details on it.
VN V6 based efi
Kalamaker modified Delco 808 ECM
VN V6 throttle body, TPS & IAC Valve
VN MAT, CTS, knock sensor and oxygen sensor
2 bar MAP sensor
VP injectors
3.2l Jackaroo V6 ignition module & VR V6 coil packs.
the only thing left to figure out is how to setup this crank trigger.
At the moment im leaning towards making a new CAS mount so as i can reduce the diameter of my trigger (2mm disc bolted to balancer).
Posted 11 January 2006 - 11:39 PM
RACV MAN
#21
Posted 12 January 2006 - 06:24 AM
Edited by J-Rod, 12 January 2006 - 06:24 AM.
