Fuel Tank EFI Questions
#26
Posted 16 March 2007 - 03:44 PM
https://cache.gmh-to...ch/fuelpump.jpg
The legs are spring loader to hold the pump at the bottom of the tank. Fully compressed it is 240mm tall. The built in surge tank is the bottom section of the pump. It would be lucky to hold 400ml. (About the size of a can of coke)
The clear plastic tube is the fuel out line. There is a vent line to the charcoal cannister and a return fuel line.
#27 _NVMYLH_
Posted 19 March 2007 - 09:49 PM
#28 _LX_SS_
Posted 22 March 2007 - 02:45 PM
#29 _CHOPPER_
Posted 22 March 2007 - 03:22 PM
#30
Posted 22 March 2007 - 03:47 PM
What do you base this statement on. I can not find any mention in the NCOP.just curious if anyone here is understanding that any fuel fittings inside the car (including boot) are illegal for road use
http://www.dotars.go...ms_3feb2006.pdf
I personally would not fit the fuel system inside my car however half the cars on the road the fuel system components inside the car.
#31
Posted 22 March 2007 - 04:58 PM
There are a few variants of the VY/Z fuel pumps. Need to be careful how they are set up in a torana (with droptank)
All these fuel pumps are designed for a 'dead end' fuel system(no return line from the engine fuel rail.
All these fuel pumps are at 4 bar
Most of these fuel pumps have an inbuilt reg, (and the power jet on the pump assy will not operate corectly if there is another reg at the engine fuel rail) basically the pot of the pump assy will not fill satisfactorily
Here is the good news. The pumps can be made to sit at a lower compressed height. If you are running a 5L like me, it is possible to convert to a dead end fuel system (I will be getting confirmation soon: ie my injection system will operate at 4 bar ilo of 3 bar).
I have made an alloy ring that will accomodate the pump to the fuel tank. In my case I will also utilize the standard Torana pick-up (allows use of Torana fuel sender) with the outlet blocked off.
Absolutely no fuel lines/tanks/pumps etc will go in cabin. I have seen many that do ^^^, even in hatches.
Let me know if you need pics of what I am talking about. PM if you like
Thanks, Max
#32 _nunganunga_
Posted 22 March 2007 - 05:58 PM
#33 _the gts_
Posted 22 March 2007 - 07:16 PM
HATCH
how short can you make it? I dont have flares or anything so I am just going to make an aly tank, it wont be a drop tank probably same as original size. I was planning to have surge tank etc all inside the tank.
I am going to use a holley stealth ram on a 500hp 383 chev so i guess pressure would only be determined by what the injectors require
would it be better to have an adjustable regulator.
#34
Posted 22 March 2007 - 07:29 PM
These are the rules that are in effect for states that have adopted the NCOP. WA has adopted the NCOP. I was directed to this site by the WA technical division when I applied for permits for my modifications. They listed which sections of each document my modifications had to comply with.The link provided to the transport site dated 3 feb 06 is a misleading publication. It is only a propasal and isnt in affect. The real code of practise is diffrent. Which efi car has any part of its fuel system other than sender wire entering the cabin?
http://www.dotars.go...n/vsb_ncop.aspx
Your original statement was.
In my response I was thinking of early Holden's eg. HK sedan with fuel tank in the boot or EH waggon with fuel tank in back section with fuel lines running out of the top of the tank. Most LPG cars have the fuel system mounted in the boot.
#35 _LX_SS_
Posted 22 March 2007 - 08:51 PM
check everything throughly, you can have surge tanks, etc mounted in the boot so long as they are A. a sealed item and B. all the connections including fuel lines are not inside the car.
doesn't matter if its a HR or LH torana, you don't comply with car manufacture year, you comply with the standards of today, standards set in when the mod is approved if you want to get it done.
other thing too is, there are different rules for us modifying our cars and what comes out standard on a motor vehicle. for example, wheel spacers or hub adapters, illegal UNLESS the motor vehicle had them standard.
to cover the fuel filler, check VSI no 8. fuel filler and cap must be located on the outside of the vehicle unless done otherwise by the manufacter.
also check NCOP9_Section_LM_Fuel_Systems_3feb2006.pdf under revision 2.2
if u read that u'd understand that a your last statement bout the filler, and it also says ' any apertures created to allow for the installation of fuel tanks (including fuel pumps and lines ) must be suitabily sealed in to prevent entry of fumes in the cabin. i'd have to look a little further into the fuel lines specific part , but i have seen it somewhere.
#36
Posted 22 March 2007 - 09:12 PM
Actually i think that is about right.
Edited by ALX76, 22 March 2007 - 09:20 PM.
#37 _LX_SS_
Posted 22 March 2007 - 09:21 PM
Edited by LX_SS, 22 March 2007 - 09:22 PM.
#38
Posted 25 March 2007 - 01:54 AM
Also dont recirculate fuel from the injector rail back into the surge tank. All this does is heat the fuel up too much.
I dump the fuel straight back into the tank but my intank pump is good enough to supply my 044 pump via the surge tank.
I ended up mounting my intank pump via the original fuel sender but was a bit of piss farting around but worked good with no cutting. My intank pump is quite small (but flows heaps) and just fit in the original hole.
#39
Posted 25 March 2007 - 01:58 AM
#40
Posted 25 March 2007 - 02:33 AM
If you do not return fuel to the surge tank then you have defeated the purpose of the surge tank. If your lift pump is sucking air due to low fuel and g-force at the return line is to the tank then the EFI pump will empty the surge tank in seconds.Also dont recirculate fuel from the injector rail back into the surge tank. All this does is heat the fuel up too much.
This will help with the fuel heating problems.
http://www.vpw.com.a...6&PrdGrpID=2287
Connecting the lift pump to the second highest connector and the return line to the highest connector on the surge tank will also reduce the buildup of heat in the surge tank.
#41 _the gts_
Posted 25 March 2007 - 08:07 AM
If you have one pump pumping into the surge tank why would you need the return line going into the surge tank?
#42
Posted 25 March 2007 - 11:44 AM
This is an Aeromotive weld in sump.
http://www.aeromotiv...ail.php?prod=66
A surge tank is a small fuel tank that holds 1-4 litres. Typically they a tall cylinders so they are not affected by G-forces. Fuel is pumped into the surge tank by a electric pump (lift pump). The EFI pump sucks fuel from the bottom of the surge tank and returns excess fuel to the top of the surge tank. Excess fuel in the surge tank is returned to the main tank from the top of the surge tank.
Typical surge tank.
http://www.tweakit.n...products_id=126
Typically fuel is pumped by the EFI pump from the surge tank through the fuel rails to a regulator. The regulator allows excess fuel to escape down the return line. The Bosch 044 is rated at 200 litres per hour with a pressure of 5 bar. Fuel will be travelling from the surge tank through the rails past the regulator and down the return line a 200 litres per hour less the fuel consumed by the engine. That is about 1 litre every 18 seconds.
http://apps.bosch.co...s/fuelpumps.pdf
If the unused fuel is not returned to the surge tank and the lift pump is sucking air then the surge tank will run dry. If the lift pump will never suck air then you do not need a surge tank. If you need a surge tank then you must connect the return line to the surge tank.
None of the fuel systems on this page have surge tanks or lift pumps because they all use the sump or fuel cell to guarantee fuel supply.
http://www.aeromotiv....com/system.php
#43 _the gts_
Posted 25 March 2007 - 02:13 PM
so if i were going to make my own aluminium tank and wanted everything inside the tank what would be the best set up for 550hp + 150 shot nos?
#44
Posted 25 March 2007 - 04:55 PM
A1 Hi Performance
Unit 4/49 McCoy St
Myaree 6154
Western Australia
Ph: +61 (08) 9317 1915
I can show you how I am going to fit the surge tank, lift and EFI pumps to my Brown Davis drop tank.
I am not sure if you will be able to register a car in WA with a home made fuel tank. It is my understanding that the a fuel tank must have the manufacturers identification stamp and there is a list of approved manufacturers. You may want to check with the WA Technical Section.
9351 1681
Edited by ls2lxhatch, 25 March 2007 - 04:56 PM.
#45 _LX_SS_
Posted 05 April 2007 - 09:26 PM
nos is illegal for road use regardless,
and your not able to build ur own fuel tank for road use, unless its been passed by the correct authorities.
its jsut as easy and cost effiencent to get brown davies in qld to make it for you.
#46 _the gts_
Posted 18 April 2007 - 07:11 PM
