what to do with my L32
#326
Posted 21 July 2012 - 05:47 PM
#327 _My74LH_
Posted 25 July 2012 - 06:22 PM
Also fitted the fuel rail and throttle cable bracket using the standard cable, and new Air filter , not a bad result .although the pedal is somewhat firm .
Don't pick on my carby bolts , im still waiting for the right ones to arrive .
Edited by My74LH, 25 July 2012 - 06:22 PM.
#328 _Jas76hatch_
Posted 25 July 2012 - 07:00 PM
#329 _LJ355_
Posted 25 July 2012 - 07:19 PM
#330 _My74LH_
Posted 25 July 2012 - 07:42 PM
looking good mate take one of the springs off the bracket it will make the throttle a little lighter
Yeah tried that but the pedal doesn't return back quick enough with only one spring. I’m going to test the spring pressure and try to find 2 lighter replacements, about 30% less.
#331
Posted 25 July 2012 - 07:47 PM
Any ideas on what to fill the choke hole with?
Choke plug?
http://www.rarespares.net.au/GoldCoast/ProductPage.aspx?product=9930800
#332 _My74LH_
#333
Posted 25 July 2012 - 08:00 PM
I would expect the springs to raised or at least horizontal at the throttle end when the throttle is closed. It the picture the springs appear to be pointing down at the throttle end which would explain why they have trouble closing the throttle.
Edited by ls2lxhatch, 25 July 2012 - 08:01 PM.
#334 _My74LH_
Posted 25 July 2012 - 08:24 PM
The angle of the spring bracket where it is attached to the throttle does not look right in the photo.
the throttle is closed in the pic , the problem, although I won’t call it a problem is not with closing the throttle it’s with the firmness of the pedal , the reason the spring brackets in this position is this it gives the least extension to the spring on a arc . Throttle return is great.
#335 _likatiger_
Posted 26 July 2012 - 09:02 PM
Not sure if anyone else has picked it, but with directional tyres, you have them on the wrong way. Shouldnt they be on opposite sides of the car?? Great looking car though, giving me heaps of inspiration.
Edited by likatiger, 26 July 2012 - 09:05 PM.
#336 _My74LH_
Posted 27 July 2012 - 05:42 PM
I was waiting for that, I hadn’t changed them around as I still had the standard height springs in there, but today they were changed as the new lowered springs arrived. I did need to remove the engine again today so I took the opportunity to drop the springs in as well. If anyone is interested I have a standard height set of front king Springs KHFS-14 for sale $50 pic on bottom .
Edited by My74LH, 27 July 2012 - 05:48 PM.
#337 _My74LH_
Posted 28 July 2012 - 03:14 PM
#338 _My74LH_
Posted 20 August 2012 - 04:21 PM
Edited by My74LH, 20 August 2012 - 04:22 PM.
#339 _Liam_
Posted 20 August 2012 - 08:51 PM
#340
Posted 30 August 2012 - 02:25 PM
I once recall seeing a 2c piece glued in there.
s
#341 _LH SLR 3300_
Posted 30 August 2012 - 04:29 PM
#342
Posted 30 August 2012 - 05:45 PM
Choke plug?
Edited by hanra, 30 August 2012 - 05:46 PM.
#343 _D Train_
Posted 10 December 2012 - 07:19 PM
#344 _connors_
Posted 11 December 2012 - 05:36 PM
Posted 14 April 2013 - 11:30 PM
So what's happening with this one?
Should be nearly finished by now hey?
#346 _LH8VD69_
Posted 18 April 2013 - 06:08 PM
#347 _SLEDGE_
Posted 21 April 2013 - 02:44 PM
+1 for give us an update!
#348
Posted 21 April 2013 - 02:48 PM
I actually thought it was your car Sledge and then when I realised it wasn't I started to wonder if its done yet.
#349
Posted 21 April 2013 - 03:32 PM
Says 74LH has been offline since Oct last year
Was wondering how this was going as well
#350 _My74LH_
Posted 20 May 2013 - 08:34 PM
Hey guys, its bin a while since my last post.
The SLR has been at a standstill since last year, it was meant to be finished by Christmas last year but a sudden family holiday to Italy got in the way.
Since then I have taken on another 2 resto projects a 74 Ducati 750GT and a 84 Ducati Mike Hailwood add to that work and two growing boys that have developed a taste for fishing, I’m busier than a one legged man in a butt kicking contest , So the Torana is just sitting there .
It’s almost finished; I have all the parts needed to finish it. What’s remaining is the fuel tank and lines, drive shaft , exhaust and some small electrics, then fit the 2 front seats and it’s finished.
I hope to get on to it by the end of the year fingers crossed , I just want to finish the GT 750, just waiting on the motor and wheels , paint is done and I have all the parts to finish it .
So lets wait and see what happens in the following months .
