I run 15x8 all round, the photo of my car makes the rears look bigger?
The front and rear has Ford Stud pattern.
BUT, i have a special length 9 inch diff fitted so that the wheels and tyres fill the guards. They (very minor) scrape in a couple of spots. I use Yoko 225/60/15 AO32R Tyres
The fronts just touch the upper wheel tub next to the inner guard and lightly on the outer guard. The rear part of each front wheel tub needed hitting back ie about where front mudflaps would normally be fitted, as they would have rubbed on full lock. I run Wilwood 4 spot Front calipers.
The rears lightly touch the outer wheel arches.
The wheels (Qty 8) were bought from Mullins Wheels Cheviot Rd Salisbury SA back in 1996 for $1528. The wheels are 18mm neg offset. part no. 152-580N18-54C. The guy I bought the car from gave me all the tech sheets about the car, which helps in times like this.
Edited by LXChev366, 01 July 2007 - 05:49 PM.
