Challenger Wheels 15x10 - anyone seen them
#76
Posted 19 July 2007 - 08:05 PM
No they don't fit over our brakes
Close... but would need about a 5mm spacer or some machining of the wheel
And they don't fit Alex's Wilwoods either
Which are not the same as either of the 2 sets in this thread
#77
Posted 19 July 2007 - 08:11 PM
We need an alloy hat that spaces it out or something similiar..Thats the B45s centre sitting hard up against the caliper and still 10mm or so short..
Suggestions Oh Great One? Interesting that the 14 x 8 Hotwires clear...dont make me go 15 x 10 hotwires..the wallet cant handle it.
Edited by rorym, 19 July 2007 - 08:14 PM.
#78
_MRNOS_
Posted 19 July 2007 - 08:15 PM
#79
_MRNOS_
Posted 19 July 2007 - 08:28 PM
4/ Keep you standard disc stub, mount to the rear, and bolt on our 290mm by 28 kit with no cutting or hitting of anything. Minimum 15 inch wheels needed, same problems needing 8mm spacer for Simmons. (You Torana guys seem to love those Simmonds wheels too!)
#80
Posted 19 July 2007 - 08:37 PM
_MRNOS_
Posted 19 July 2007 - 08:44 PM
http://www.hoppers.c...2007/index.html
Looks like regardless of brakes, if I use the simmons I may need a spacer...???
Taking into account what my car will be used for, 1 lap type racing, not several, what brakes would be best suited????????????? I aint selling my simmons!!
Edited by MRNOS, 19 July 2007 - 08:47 PM.
#82
Posted 19 July 2007 - 08:59 PM
#83
Posted 19 July 2007 - 09:04 PM
Edited by rorym, 19 July 2007 - 09:11 PM.
#84
Posted 19 July 2007 - 09:07 PM
Heres the answer...the hotwires have a built in 15mm spacer at the back...backspace is 4 1/2 inches on a 14 x 8.
_MRNOS_
#86
_MRNOS_
Posted 19 July 2007 - 09:08 PM
#87
_82911_
Posted 19 July 2007 - 09:13 PM
Datto I am wondering if longer studs and an alloy spacer will solve the problem..only thing then is it throws the offset further out.
Yes Rory it will...
But on a positive note it will improve your scrub radii and do lots of good things for your steering geometry.
I had a similar problem recently, except I went the other way and got a deeper hat with more offset and spaced the caliper further inboard. I wouldn't suggest you guys do that.
Sams solution looks the most workable, and his wheels are on a dedicated track car that will see much more stress than what you guys are planning.
Cheers Greg..
Edited by 82911, 19 July 2007 - 09:15 PM.
#88
Posted 19 July 2007 - 09:15 PM
Yep..then you reduce that offset in the rims..i.e.,...that bit you spaced gets added to the inner rim and taken off the outer rim..understand? They do it on open wheelers all the time. I am not sure you need to do the double nut thing Sam did..if you use thicker threads..then the wheel bolts up hard to say...a 15mm spacer it should be OK..BUT!..the hotwires and Challengers has their spokes actually pointing out to the outer rim..that angle might also be needed to clear the calipers..so it may be more than 15mm...if you get my drift.
Edited by rorym, 19 July 2007 - 09:19 PM.
#89
Posted 19 July 2007 - 09:17 PM
Did you use DBA 4000/5000s?..I cant find the measurements or spec on their website,..only the std road stuff.
_MRNOS_
#91
Posted 19 July 2007 - 09:20 PM
_82911_
Posted 19 July 2007 - 09:22 PM
told you it wouldn't help.
Cheers Greg..
#93
_MRNOS_
#94
Posted 19 July 2007 - 09:23 PM
We still have no solution to the problem that i'm happy with.
Not prepared to accept spacers as the solution.
Not a lot i can do till iget home anyway. Although Datto is doing a stirling job in looking for options.
Welby
#95
_MRNOS_
Posted 19 July 2007 - 09:25 PM
Edited by MRNOS, 19 July 2007 - 09:26 PM.
#96
Posted 19 July 2007 - 09:32 PM
_MRNOS_
Posted 19 July 2007 - 09:33 PM
#98
Posted 19 July 2007 - 09:34 PM
Theres the clue...now where are those old pics of Gregs front brake setup?It's not going to help!!!!!!
ummm.... volvo 264....
told you it wouldn't help.![]()
Cheers Greg..
Posted 19 July 2007 - 09:41 PM
See here is the problem if you go Sams way..maximum out for the rim..nearly/probably touching the outer guard...these are 15 x 8...now add in 15 x 10..See my problem?..They are through the guards.
Edited by rorym, 19 July 2007 - 09:44 PM.
#100
Posted 19 July 2007 - 09:59 PM
