Challenger Wheels 15x10 - anyone seen them
150 replies to this topic
#126 _Chaotic_
_Chaotic_
Posted 25 July 2007 - 11:13 PM
Out of curiousity i should have a trade going price on performance challengers tomorow. asked for prices in both 15x8 and 15x10 i'll throw up tomorow what i'm able to get them for, if any of the perth people are interested.
#127 _Chaotic_
_Chaotic_
Posted 26 July 2007 - 04:53 PM
Got priced $265 landed per wheel, and aparantely theres 0 stock of the 15x10 for 6-8 weeks, but plenty of 15x8 on the shelf.
#128 _rorym_
Posted 26 July 2007 - 05:30 PM
Bob Jane Maryborough quoted me $275 each landed for the 15 x 10.
#129 _rorym_
Posted 28 July 2007 - 12:56 PM
One for REDA9X...The Gough/Barry Sheales car runs Challengers all round...Do you know him?..Can we find out if he had any dramas on the fronts?..If so how did he get around it?
#130 _rorym_
Posted 08 August 2007 - 09:46 PM
Bought the 15 x 8 Challengers off Ebay today..2 used..2 brand new...at a pinch they will be my wets..I am ordering 2 - 15 x 10 to see what fits where...I am covered either way! :clap:
#131 _rorym_
Posted 13 August 2007 - 01:18 PM
This is what I have done with mine, I know it looks like a ridiculous size spacer, but as you can see, it has been secured using the studs with a lock nut on each one, that way the studs are supported
Sams spacer
#132 _rorym_
Posted 13 August 2007 - 01:22 PM
See here is the problem if you go Sams way..maximum out for the rim..nearly/probably touching the outer guard...these are 15 x 8...now add in 15 x 10..See my problem?..They are through the guards.
I just realised Sams spacer is about 2 inches...so pushes his front wheels out that far..if that is the case..15 x 10 should be close to being OK.
15 x 8 105mm backspace...95mm outer lip.
15 x 10 113mm bacspace....142mm outer lip.
These the 2 inches I need.
#133 _rorym_
Posted 17 August 2007 - 04:34 PM
If you look at that Gough car up there ^^^ you will see they are struggling to get the 10s under the front...I think it is going to be a drama...will be nothing but a pain in the arse with rubbing..we will see...the fronts below will need 35mm added to the outside if they are 10s...thats level with the out side of the flares...The backs will just fit..
The rears below
Looks HORN!!
#134 _MRNOS_
_MRNOS_
Posted 17 August 2007 - 04:45 PM
So thats the 8's??
#135 _rorym_
Posted 17 August 2007 - 04:57 PM
Yep...In the second pic I stood a straight edge against the outside of the flare...thats where the outer edge of a 10 will be on the front..I reckon we are 8 fronts ...uncut wets...and 10s on the rear with soft compound slicks. In fact on the Gough car...the fronts look a bit weird..like they are too big?..or is it just me?
Edited by rorym, 17 August 2007 - 04:58 PM.
#136 Racehatch
Racehatch
  • 1,027 posts
Posted 17 August 2007 - 05:00 PM
How much neg camber will you be running with the slicks? That will tip the top of the wheel inside the guard more... although turning may still present some clearance problems..
#137 _rorym_
Posted 17 August 2007 - 05:04 PM
Now imagine Sams car with an extra 40mm/2 " on the rear bags...That will look the mumble.
#138 _rorym_
Posted 17 August 2007 - 05:06 PM
Stuckey tells me 3.5 to 4 degree neg needed for the radial slicks.
#139 Racehatch
Racehatch
  • 1,027 posts
Posted 17 August 2007 - 05:15 PM
haha you mean Peter!
Yeah would look way cool! I'd love to check out the difference in traction verses the little tyres we run now..
#140 _rorym_
Posted 17 August 2007 - 05:20 PM
Oops!..Meant Peter..Yeah Stuckey says use uncut wets on the 8 fronts..and softs on the rear 10s....makes sense actually..its sprints/hillclimbs and you need heat and stickiness in the tyres from scratch...wouldnt do 5 laps at a sprint though...
#141 _rorym_
Posted 19 August 2007 - 02:04 PM
#142 _LXChev366_
_LXChev366_
Posted 23 August 2007 - 07:23 AM
I took this photo ages ago, but its relative to this thread. Now keep in mind I have a custom length 9 inch diff. Front and Rears are 15x8 with 225/60/15.
#143 _rorym_
Posted 23 August 2007 - 10:36 AM
My rear 8s have 2" clearance on the outer edge......fronts look the same ^so if you go the bigger fronts it will push the 10s out level with the outside of the flare...not a good look...See the Gough car back there..^^.
#144 _rorym_
Posted 19 June 2008 - 09:38 AM
My head hurts....I am back to here.. :cry:
#145 _MRNOS_
_MRNOS_
Posted 19 June 2008 - 11:46 AM
Just come try my simmons
#146 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 19 June 2008 - 12:34 PM
My Simmons clear my Harrops nicely.
Big bolt up face.
Photos on the for sale page for reference.
Welby
#147 _rorym_
Posted 19 June 2008 - 02:13 PM
Welby,
Thats the 20mm I am missing..
#148 yel327
  • 13,633 posts
Posted 19 June 2008 - 04:00 PM
A mate of mine has a pair of these hanging in his shed, but they are a 2 or 3 piece setup. I think they are 15x9 or 15x10 in Ford pattern.
#149 _rorym_
Posted 19 June 2008 - 06:19 PM
Sorted...see my thread.
#150 dattoman
  • 16,487 posts
Posted 19 June 2008 - 07:49 PM
