my torana has a 5l vn fuel injected engine in it, the computer says code 12 systems pass. but it doesnt fire. fuel pumps seem ok, it cranks over fine. it only gives a non consistant, low spark. the coil has been replace. and we cant get to the distributer cause its way behind the engine. ive been told that the injection systems in vns are crap. im trying to get it running this weekend for our clubs power cruise. is there anyone who can come out to bullcreek and test the injector module?
VN 5L INJECTOR
_[Azer]_
, Mar 27 2007 08:24 PM
8 replies to this topic
_[Azer]_
Posted 27 March 2007 - 08:24 PM
_[Azer]_
Posted 27 March 2007 - 09:43 PM
or does anyone know how i can test the injector module?
Posted 27 March 2007 - 09:46 PM
check the voltage to your ignition module.
needs a good 12V or nothin will happen.
How long has the engine been in the car?
Was it running before in the car?
have you checked the pink wire at A6 onthe computer for 12v?
Can u hear the injectors clicking or not?
Edited by LXdamo, 27 March 2007 - 09:53 PM.
_[Azer]_
Posted 27 March 2007 - 10:25 PM
ill check all that tomorrow.
How long has the engine been in the car?, not sure exactly, but id say a while. yes it was running till sunday.
Posted 28 March 2007 - 01:00 AM
common problem with the VN's is the ignition module.
on the V8's, holden mounted this large transistor in the middle of the circuit board of the ignition module, mounted on the passenger side inner gaurd.
in time the solder joints fracture, creating an open circuit in the solder joint.
re-solder the legs, and hot glue the thing to the CB. or just re solder.
you need 20/20 vision, or a magnifying glass to see the hair line cracks.
I have 2 VN's, both did the same thing.
easy fix. expensive to replace.
consummed 3/4 bottle port, so excuse the wording.
I had simmilar problems, the ignition module was the last resort.
2nd time round, just went straight to the module.
inside the module, the thing is about the size of a 5 cent piece, with 2 legs soldered on the opposite side to the circuit board. you can't miss it! (TO3 housing from memory)
it may be something else though.
the dissy cap does come out, just! well from the VN!
but it is empty, so not much going on in there.
leave the coil bolted to the bell housing, and mount a new one somewhere else. much easier if you are replacing it.
as said before injectors all click together, (unless it is the later sequential type), so put a big yellow screw driver at each base and listen through the handle, then pull plug off. if it is working you will hear it.
unlikely your problem though if they are clicking
fuel pressure,re-VN, hose between fire wall and fuel rail will be soft in the morning, should be hard if fuel pressure is there after the ignition is turned on.
and you hear pump start, then stop once pressure reached.
once had a fuel pump fail, there was 2, low pressure in the tank, then high to the engine. some have 2, some have 1, high presure in the tank, no external pump.
pulled the sealed external pump apart to find the windings were spinning on the impeller shaft, as an emergency I used spider wire (80lb fishing line) and tied it around the pump unit and windings to get me going, that was 10 yrs ago, need to replace that one day! spider wire is good stuff.
remember there will be a high quality filter somewhere before the fuel rail.
o/k port all gone
I have over 350k's on one VN, never had an injector problem! but that one is on lpg.
had a coil lead go once, but you would of checked that before replacing the coil.
have a gen 3 with nearly 500k's on it with no injector problems either, dam, thats on lpg as well.
think the injectors run straight off the computer? no module!
ignition modules are crap though!
o/k port all gone
_Rally hatch_
Posted 30 March 2007 - 05:54 AM
He gets chatty when he's had a few......
so basicly what you're saying is, that sometimes stuff happens to stuff and then it's stuffed?
Edited by Rally hatch, 30 March 2007 - 05:56 AM.
_LX_SS_
Posted 30 March 2007 - 06:08 AM
if u have ur igntion on, remove the dizzy from the engine, and turn it by hand, you should hear the fuel pump turn on, injectors start clicking, and if ur getting spark u'll hear a popping noise likes its trying to fire.
also could be a stupid question but has caught a few out, does the ecu have constant power when cranking ? this would make a difference.
Posted 30 March 2007 - 12:55 PM
lucky I only had one bottle! just getting primed.
should be a new forum rule, no pissed posting.
_[Azer]_
Posted 31 March 2007 - 09:02 PM
thanks for all the advice, we have sorted the problem out. apparently the injectors were only gettin 6v while cranking over instead of a full 12v.
rewired it and now its working. will be running for the CTCC Power Cruise tomorrow. yay!
