loose header bolts
YiriSS
, Jan 13 2006 03:25 PM
8 replies to this topic
Posted 13 January 2006 - 03:25 PM
anyone got any advice for these damn header bolts,
they seem to keep coming loose at least once a week.
and they are allways in a very difficult spot to get to!
im considering changing them for allen key headed ones just to get to them, but i reckon they will still work their way loose.
is there a loctite or someting similar specifically for higher temps?
mick
mick
Posted 13 January 2006 - 04:01 PM
I've noticed similar things with mine from time to time - it appears to be the rear-most bolts most affected, always just a tiny bit loose. If I leave it for ages without checking, they can become quite loose. Was also thinking maybe some Loctite is in order? Perhaps the "Stud Lock" strength?? No idea if this is ok for high temps etc..... Will be interested to hear other people's comments....
#3 _Yella SLuR_
Posted 13 January 2006 - 04:26 PM
Tis a problem, add it to your regular maintenance routine. Loctite couldn't hurt.
Posted 13 January 2006 - 07:32 PM
yeah its a constant maintenance item pat!
i will find out brett and let you know
Posted 13 January 2006 - 09:45 PM
Tighten them cold, run it, let it go totally cold then retighten them.
RACV MAN
RACV MAN
Edited by rodomo, 13 January 2006 - 09:45 PM.
Posted 13 January 2006 - 10:04 PM
thanks rob, i will try that
ive done it up cold (when its hot , the heat goes right thru the spanner)
ive ran it today, tommorow morning i will do it up again
mick
mick
#8 _Yella SLuR_
Posted 14 January 2006 - 08:41 AM
Thanks for that RACV Man. Knew there musta been a way. I got the shits with mine backing out all the time, so got the mechanic to do the last lot of gaskets. Bolts haven't moved so thought there might be bit of a trick to em.
Posted 14 January 2006 - 09:00 AM
thanks greg
they look very trick,
i will see how rodomo's trick works first, if not
i will chase up a set of those.
mick
mick
