Wondering if any ones knows if 4cylinder lc coupe front seat frames are the same as lc XU1 front seat frames. Also are thr rear seats the same ??? Any help appreciated.
lc gtr xu1 seats
71xu1
, Mar 30 2007 10:30 AM
5 replies to this topic
Posted 30 March 2007 - 10:30 AM
Posted 01 April 2007 - 12:49 PM
im gunna go out on a limb and say they are, im not 100% on the LC part, but i am under the impression that the only difference between 4cylinder and 6 cylinder is firewall forward.
Posted 01 April 2007 - 04:30 PM
I've not seen them personaly, but the parts book says that (4 cyl 2 door) 'Spring and Frame Assembly front/rear" are the same as the 82911 bits.
Posted 01 April 2007 - 04:50 PM
4cl rear back is straight across as opposed to the other models which have higher backs and a dip in the middle.
#5 _Feigz_
Posted 01 April 2007 - 10:20 PM
Had a look thru my LC Parts manual and there is no reference to different seat frames just trims etc.
Posted 02 April 2007 - 12:41 PM
Thanks for the replies. It will make the interior resto a lot easier knowing I can use the frames from a run of the mill 2dr.
