G'day All
I haven't been able to confirm that the diff in my SS Hatch is a 3.08 and I have looked in the usual spots but there are no numbers.
At how many revs at 100 Km/hr should the motor be doing with 253 V8 and M20 box and the diff being a 3.08?
Regards ............. Barry
At 100 Km/hr, what revs ?
Pop's-SS
, Apr 24 2007 10:21 PM
8 replies to this topic
Posted 24 April 2007 - 10:21 PM
Posted 24 April 2007 - 10:39 PM
You might want to add your tyre size Baz.
Posted 24 April 2007 - 11:02 PM
Add into that equation 205 x 60 x 13 inch Yokohamas
Thanks rodomo
Regards ............ Barry
Thanks rodomo
Posted 24 April 2007 - 11:27 PM
My calculation is 2836 Rpm using the "Miata" tyre size calculator "pinned" in wheels and tyres. It says your tyres have a rolling circumference of 1.81 meters per rev. My son's UC has the same size tyres and diff ratio and that is what it sat on on the way to Winton last year.
Posted 24 April 2007 - 11:30 PM
seems a bit high to me for 3.08.
#6 _CHOPPER_
Posted 24 April 2007 - 11:37 PM
The 205/60R13 is a very small diameter tyre for a Torana, which is why the revs would be higher than expected. Using my $5 calculator, I came up with the same RPM that Rob got.
#7 _devilsadvocate_
Rodomo has calculated correctly.
Posted 25 April 2007 - 09:27 PM
Mine with the 285 40 15 does around 2300 rpm at 100, my SS 253 3.08 rear with 225 50 15 did the same. If you work out the tyre diameters, it's almost identical to the originals. The VK Group A I drove today was about the same.
