Need some info my LH has the standard harness with the high beam dipper switch on the floor and my combintaion switch which is out of a LX has the high beam dipper on it aswell. My question is does the combination switch still plug into the harness okay without upsetting the high beam dipper switchi m not too fussy on which one to use just want to know if it is okay to have it like like
cheers dennis
Combinantion switch wiring
_SLR Goat_
, May 01 2007 08:51 PM
6 replies to this topic
#1 _SLR Goat_
Posted 01 May 2007 - 08:51 PM
#2 _devilsadvocate_
Posted 01 May 2007 - 09:19 PM
The LH dipper switch simply switches between high and low beam, whereas the lx indicator/dipper switch toggles a relay to do the same task. The LX indicator/dipper can not control your headlights unless you also fit the relay.......so perhaps your best choice is to leave the dipper switch as is. As far as Im aware the lx lever just bolts to the indicator mechanism in the same way as the lh.....just dont connect any the wires from the lx lever.
#3 _SLR Goat_
Posted 01 May 2007 - 09:26 PM
So u r saying only connect the wiring for the indicators? and dont worry about the dipper wiring
#4 _devilsadvocate_
Posted 01 May 2007 - 09:28 PM
....um yes, but(afaik) the stalk itself detaches from the indicator mechanism, shouldnt actually need to remove the indicator mechanism or the wiring.
Edited by devilsadvocate, 01 May 2007 - 09:30 PM.
#5 _SLR Goat_
Posted 01 May 2007 - 09:39 PM
I think i have got it pictured in my head what u mean thanks if i have any probs ill just ask again
cheers dennis
cheers dennis
#6 _MRNOS_
Posted 01 May 2007 - 09:50 PM
If you need a indicator stalk to suit a lh or lx I have both...if you need 1
#7 _SLR Goat_
Posted 01 May 2007 - 10:54 PM
Cheers ill let u know if i need one
cheers dennis
cheers dennis
