Holley or Barry Grant
#1 _micksgtr_
Posted 06 May 2007 - 10:25 PM
I'm after some advice on which is a better carby. I've got a fairly hot/wild 383 on the go at the moment and i'm looking at using a 825 barry grant or maybe a holley. Which have people used?? Which is better and why?? Which manifolds can i use with both?? I was wanting to either use a harrop single plane or a torque power manifold.
Also whats the difference between, vac and mech and a double pumper??
Posted 06 May 2007 - 10:44 PM
After having 3 holleys on the monaro ( 650 Vac, 750DP and 850DP race) the 750 DP demon i have now is the most reliable, easily tuned, and consistant carb ive used.
The holleys played up for no known reason after some time and just gave us trouble!
Vaccum secondaries use vaccum signal to activate the secondaries.. meaning that theyre better for street use, while Mechanical secondaries use a linkage to activate the secondaries.
Double Pumpers have an accelerator pump on the secondary circuiit as well as the primary circuit and are more suited to race and hi-po work. they tend to run a bit richer due to the accelerator squirts with throttle movement.
Ive always used Mechanical DP carbs even on teh street and the demon is a VERY good carb, i wouldnt go past it. It bolts on to any holley manifold. Same bolt pattern.
Good luck!
#3 _v8slrtorana_
Posted 06 May 2007 - 10:45 PM
Dollar vrs dollar, go BG.
Nothing wrong with a holley, just personal choice, having owned both.
BG, uses most holley parts too, like gaskets, jets, power valves and gaskets !
Posted 06 May 2007 - 11:07 PM
#5 _rorym_
Posted 06 May 2007 - 11:13 PM
#6 _[BOTTLEDUP]_
Posted 07 May 2007 - 01:40 AM
Bang for buck they're hard to beat, I'd suggest getting the Race Demon version though over a Mighty Demon, they have a better fuel curve and more adjustments.
Posted 07 May 2007 - 07:20 AM
I was Lucky.. I bought my mighty Demon from UltrablueA9X so it was "old stock" and also test driven
Cheers!
Posted 07 May 2007 - 08:15 AM
#9 _Big T_
Posted 07 May 2007 - 08:37 AM
Edited by Big T, 07 May 2007 - 08:42 AM.
Posted 07 May 2007 - 03:20 PM
Don't see much off them.
Posted 07 May 2007 - 07:59 PM
I personally prefer Holley and have seen HP series 750's outpower BG's repeatedly.
BG's do have some good features and look the part, perhaps this is what you are paying for ??
Most Holleys that people have trouble with are 20 years old and way off base settings.
FWIW the Dambest carbs are loosely Holley based and damn expensive.
Lately I have used a few Proform carbs (chinese Holley HP copies) both as body upgrades and complete carbs and they have all performed exceptionally.
Hope this helps.
Posted 07 May 2007 - 08:26 PM
#13 _[BOTTLEDUP]_
Posted 07 May 2007 - 09:16 PM
FWIW, I'm running a Pro-Systems Dominator, which is a Holley Dominator modified by a race carburettor specialist in the USA. Haven't used it yet, although my carb has been used on a 427 Windsor, and produced 730+hp on 98 octane pump fuel.
Dambest carbs are extremely good, from what I've seen in the US, but their cost is prohibitive IMO for them to be seen in Australia in any great numbers.
Posted 07 May 2007 - 09:35 PM
I buy the bodies and Quickfuel blocks from Summit.Agree with Struggler, I've also supplied customers with Pro-Forms, and been very happy with the results I've seen. I feel that they are over priced though, our friends at Rocket/VPW need to sharpen up the pencil.
Complete carbs from eBay here in Aust. Some guy in Melb. had quite a few and I think they were about $750ea ? I haven't seen them advertised for a while.
Posted 08 May 2007 - 02:41 PM
Welby
Posted 08 May 2007 - 06:28 PM
Posted 08 May 2007 - 08:28 PM
#19 _micksgtr_
Posted 08 May 2007 - 09:44 PM
#20 _Rzeractor_
Posted 08 May 2007 - 10:08 PM
anyone got a 525cfm demon or a 465 holley for sale?
#21
Posted 08 May 2007 - 11:20 PM
havent seen one in the flesh but would be the bees knees for v8 manifolds with runners to each intake port , no more lean front and back cylinders !!!
#22 _wabbit_
Posted 09 May 2007 - 05:25 PM
dit and finish aside, the BG carbies seem a better proposition than Holley.
BG has machined throttle plates and metering blocks, whereas the Holleys are cast and can have air leaks.
i believe that proform and quickfuel also do the machined parts
#23 _rorym_
Posted 09 May 2007 - 05:32 PM
Posted 09 May 2007 - 06:09 PM
$650 + tax at the moment from Wocket
#25
Posted 10 May 2007 - 12:03 PM
