My Pro street style rear end
#326
Posted 07 September 2009 - 10:33 AM
#327
_why-psi_
Posted 09 September 2009 - 11:20 PM
progress?????
not a great deal lately. made a bonnet catch support. pumped up a flat tire. sat inside torana.
blower rebuild is next. when i get tax $$
#328
Posted 09 September 2009 - 11:25 PM
#329
_why-psi_
Posted 23 September 2009 - 06:00 PM
Edited by why-psi, 23 September 2009 - 06:01 PM.
#330
Posted 24 September 2009 - 08:54 AM
My car was in the shed at the folks house and it got covered too.
Im just worried about it scratching the paint when washing it off, might have to bust out the pressure washer to rinse it first.
#331
_why-psi_
Posted 26 March 2010 - 04:48 PM
going overseas for 2 months, got a new job. means i get paid out all my longservice leave and anual leave from bunnings which should net me close to $6500 of "torana money"
so in around september to december i plan to get the engine running.
#332
Posted 26 March 2010 - 06:17 PM
#333
_why-psi_
Posted 20 June 2010 - 03:36 PM
Will be getting stuck back into the torana after my Europe trip which is coming up in 9 days!
#334
Posted 21 June 2010 - 08:43 AM
Got the size right too! hahaha, I should see if i can make up a tiny little one for your model!
#335
Posted 25 June 2010 - 02:22 AM
I would have thought that comp ratio a bit low, properly ok with super charger but didn�t you say it was originally a turbo motor would have had some lag in her before boost came on then pow hit with heaps of power.got some numbers
its bored .040 which makes it a 206. head chamber should be 72cc, comp ratio works out to be 6.84:1 lovely for boost
churned out 330hp @ 7500 rpm, 275 lb-ft @ 5000 on Desktop Dyno 2003.
ran a 12.3 @107mph on Desktop Drag 2003
#336
_why-psi_
Posted 23 September 2010 - 10:46 PM
heres a couple of pics for the hell of it
#337
Posted 24 September 2010 - 08:31 AM
#338
_why-psi_
Posted 24 September 2010 - 10:42 AM
#339
_why-psi_
Posted 29 September 2010 - 06:09 PM
ECU selected...
Injector number and size determined.. 6x 700cc
injector hat selected...
and i gotta make/get this badly photoshopped by me item made. it houses 6 injectors and adapts the injector hat from 6/71 outlet to 4/71
now to save some folding stuff. a fair bit of it
#340
_why-psi_
Posted 08 October 2010 - 05:54 PM
Found a place in Wetheril Park to get Aluminium. thyssenkrupp aerospace they supply Boeing and Airbus with materials.
$88 later and i went home with a 480x230x25.4 plate of 6061 aluminium.
marked out
DIY-CNC machining
its not as bad to cut as i thought it would be. still hard work.
#341
Posted 08 October 2010 - 05:59 PM
And I mean PLENTY..
#342
_why-psi_
Posted 08 October 2010 - 06:07 PM
plenty of WD 40 will make your life easy with the jigsaw.
And I mean PLENTY..
yeah im using Cutting oil. only using the jigsaw where i cant touch with the grinder. once its cut out is the long and boring filing of the edges
#343
Posted 08 October 2010 - 06:28 PM
This is where NOFX on the stereo comes in real handy...fasterfasterfaster..hehehe..
dont forget to lube the file liberally too.Works heaps quicker and neater..
#344
_2wild4u_
Posted 08 October 2010 - 11:21 PM
#345
Posted 09 October 2010 - 06:13 AM
#346
_why-psi_
Posted 09 October 2010 - 02:24 PM
vacuum port to brake booster
#347
Posted 10 October 2010 - 08:33 PM
#348
Posted 11 October 2010 - 11:19 AM
#349
_why-psi_
Posted 13 October 2010 - 10:39 AM
took a while to figure how id plumb it but worked it out.
#350
_why-psi_
Posted 03 November 2010 - 04:25 PM
no more playing with Carburetors for me
