My Pro street style rear end
369 replies to this topic
#26 _why-psi_
_why-psi_
Posted 13 May 2007 - 08:44 PM
anyone else running coilovers on the back of an LJ-LC? what spring rate are you runing if you are?
Edited by why-psi, 13 May 2007 - 08:45 PM.
#27 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 15 May 2007 - 09:08 PM
did u use orig shocker mounts or no room too?
#28 _why-psi_
_why-psi_
Posted 15 May 2007 - 10:15 PM
original shock mounts wont let a big tire wheel combo. so i welded a crossmember between the 2 rails and welded brackets to that for the top and welded adjustable brackets to the diff
#29 _the gts_
_the gts_
Posted 15 May 2007 - 11:19 PM
Thanks for the pics and info. Tubs are next on my list when motor is in.
did you buy the sheet metal for the tubs or make up yourself?
#30 _why-psi_
_why-psi_
Posted 16 May 2007 - 12:34 AM
i used my old bonnet for the sheetmetal :rockon:
#31 _lctorana71_
_lctorana71_
Posted 19 May 2007 - 11:13 PM
hey loks good, have u go any external shots of the car? wats next on the list of things to do on her?
#32 _why-psi_
_why-psi_
Posted 20 May 2007 - 01:57 AM
no finished external shots yet. next on the list is the alloy fuel cell, more braided lines and fittings, HQ front brakes, find a diff centre for the 9inch and shorten tailshaft
#33 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 20 May 2007 - 12:12 PM
Perhaps you should chat to dattoman about brakes before you go out and buy the HQ type. I have HQ on my LJ and they are fine, but its good to see if there are other options :spoton: i suspect commodore discs are better??
#34 gtrboyy
gtrboyy
  • 3,208 posts
Posted 20 May 2007 - 03:22 PM
Chat to dattoman,i used commodore brakes & liked them better than the hq brakes had on before.
Did find out the spring rates to use,the ones I had on the back of mine are way too stiff.
#35 _why-psi_
_why-psi_
Posted 20 May 2007 - 08:18 PM
cool, havent found out what spring rate yet, i was thinking 200lb? this sound right???
#36 gtrboyy
gtrboyy
  • 3,208 posts
Posted 21 May 2007 - 04:10 PM
Just looked at mine 250lbs,way to stiff lol.I think it had 160-180lb springs in it before,problem with those was that the car would squat too much & the tyres would rub on the guards.
It did however hook up/launch better with the softer springs.I was told that I should have had the car corner weighted or something to find out the correct poundages for springs to use.
#37 _why-psi_
_why-psi_
Posted 22 May 2007 - 12:25 AM
cheers gtrboyy, i think im gonna go with the 200lb springs. anyone got other ideas befor i order them?
#38 _JBird_
_JBird_
Posted 23 May 2007 - 11:07 PM
Whats the biggest wheel and tyre combo you can run?
#39 _why-psi_
_why-psi_
Posted 23 May 2007 - 11:21 PM
should be able to fit a 15x10 and 285 wide tires
#40 _why-psi_
_why-psi_
Posted 27 May 2007 - 05:56 PM
I finished the mount for the fuel cell today :)
i did it this way so i can go back to a standard tank if i need to
#41 _Bedford_
_Bedford_
Posted 03 June 2007 - 08:34 PM
Nice work on those tubs.
I'd decided not to tub my LC, but you just make it look easy... hmmm...
hehe.
Couple of quick questions for you...
What state you from?
What engine you running?
Did you buy your 9 inch new, or 2nd hand, and is it standard length or shortened?
#42 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 03 June 2007 - 10:34 PM
why-psi, whats the engineer thinking of it?
#43 _why-psi_
_why-psi_
Posted 04 June 2007 - 11:21 AM
im from sydney. im running a 202 at the moment, the new engine wil be a 202 with sequential EFI, no distributor, and 6 throttlebodies.
i got my 9 inch second hand. its been shortend to suit the LJ and is a bit wider than standard ( its to suit commodore offset wheels)
i am going to get it shortened another 3 inches either side though.
just decided to add a bar for bracing the coilover brackets
#44 gtrboyy
gtrboyy
  • 3,208 posts
Posted 04 June 2007 - 11:57 AM
what is your diff width?
I think mine is 1370 from memory,wider than lc/j to fit my vt grange rims.Wish I had gone a bit narrower now so I could have tucked the wheels under the wheel arches more as there is no way I want to modify the std arches as I like the way they look std.
#45 _why-psi_
_why-psi_
Posted 04 June 2007 - 12:04 PM
not too sure bit its also around about 1370. craft diffs are going to charge me 550 to chop 3 inches off each side. that way i can have the wheels in the gaurds and fit the 15x10s.
#46 _why-psi_
_why-psi_
Posted 03 July 2007 - 03:46 PM
fuel cell and springs arrived today :)
now just gotta plumb the fuel cell and its just about done
#47 _JBird_
_JBird_
Posted 03 July 2007 - 04:17 PM
Nice.
What are your mounts made out of? What size steel.
#48 _big_als_army_
_big_als_army_
Posted 03 July 2007 - 05:50 PM
Nice work there mate. Mini tubs with coil overs for <$1k, thats just unheard of! I like the way you have done it by modifying and adding to the original steel instead of just chopping the whole lot out and going for pre-rolled sheet tubs. Whats your background in relation to the welding and sheetmetal work you've done or have you just picked it up along the way? Did you do the cage too?
If you take that diff to Craft to get shortened, that will be the 3rd time they have modified it! I got ladder bar brackets taken off it and standard LC/LJ mounts put on originally, then they mucked it up and one side was out so they re-did it. If you are going to run 15" x 10"s with 275's or whatever, I'd consider getting new billet axles made up with thick flange plates and 1/2" studs. I can see you twisting an axle and/or shearing studs pretty easily.
#49 _Monkey_
_Monkey_
Posted 03 July 2007 - 06:01 PM
Good advice.
I run a 275 tyre and twisted some stockies now have 31spline mosers, problemo solved :spoton:
#50 _lctorana71_
_lctorana71_
Posted 03 July 2007 - 11:46 PM
hey mate looks real nice, do you think the 200Ib spring is the go or is it to stiff??
