My Pro street style rear end
#51
_why-psi_
Posted 03 July 2007 - 11:58 PM
i used a QA1 mounting kit, comes with all you need. the brackets are 1/4 inch thick steel i think.
i used a 125LB spring, one of the salesman at VPW gave me a call and worked out 100lb by some formula so i just went with the 125lb springs and ill see how it goes.
#52
Posted 04 July 2007 - 07:52 AM
#53
_big_als_army_
Posted 04 July 2007 - 12:58 PM
Well thats even better work you've done there then mate, keep it up!hey thanks, i have no background in welding or anything, i just picked it up along the way. ive always loved cars and just read alot of magazines and books and just teach myself pretty much.
#54
_why-psi_
Posted 04 July 2007 - 06:01 PM
#55
_lcv871_
Posted 04 July 2007 - 10:34 PM
good job
#56
_big_als_army_
Posted 04 July 2007 - 11:18 PM
#57
_why-psi_
Posted 05 July 2007 - 07:59 PM
#58
_big_als_army_
Posted 05 July 2007 - 09:44 PM
#59
_why-psi_
Posted 10 July 2007 - 11:51 AM
#60
_big_als_army_
Posted 10 July 2007 - 12:42 PM
#61
_why-psi_
Posted 10 July 2007 - 05:26 PM
#62
_big_als_army_
Posted 10 July 2007 - 05:31 PM
#63
_why-psi_
Posted 10 July 2007 - 05:51 PM
#64
_big_als_army_
Posted 10 July 2007 - 05:56 PM
You may as well go a inj V8. That fuel system and mini tubs are set-up perfectly for one.
#65
_why-psi_
Posted 10 July 2007 - 05:59 PM
#66
_why-psi_
Posted 15 July 2007 - 05:02 PM
#67
_big_als_army_
Posted 15 July 2007 - 05:41 PM
It would probably cost less than whatever 6 cyl efi set-up you're thinking about putting in it. Engineering for a V8 is pretty easy to pass, you just need a V8 gearbox, diff and brakes and a couple of LH/LX uni joints in your steering shaft. They can engineer it for all that at the same time you get your 9", tubs and cage engineered.that would be big bucks to dit tho wouldnt it? and engineering is reallllllllllllly hard now
Your boot is looking great now mate. I can't wait to see the rest of it, especially if you go as V8 conversion as it will be one tidy car.
#68
_big_als_army_
Posted 15 July 2007 - 05:43 PM
#69
Posted 15 July 2007 - 07:31 PM
and also already has majority of the bits he needs to do the injected six.
#70
_big_als_army_
Posted 15 July 2007 - 07:52 PM
#71
Posted 15 July 2007 - 08:06 PM
#72
_big_als_army_
Posted 15 July 2007 - 08:13 PM
#73
_jap-xu1_
Posted 15 July 2007 - 09:14 PM
#74
_big_als_army_
Posted 15 July 2007 - 09:18 PM
Have you had one passed by doing this?the fuel cell will pass if all the holes in the rear firewall are welded up
#75
_why-psi_
Posted 15 July 2007 - 09:50 PM
