My Pro street style rear end
#101
_why-psi_
Posted 14 October 2007 - 11:36 PM
#102
_dave720gtr_
Posted 15 October 2007 - 06:01 AM
#103
_@milco@_
Posted 15 October 2007 - 04:55 PM
thats a sexy carby.
#104
_why-psi_
Posted 12 November 2007 - 07:52 PM
#105
Posted 12 November 2007 - 09:23 PM
#106
Posted 13 November 2007 - 08:30 AM
i noticed in another thread that you said it was mounted to the column shift shifter bulge.
looks spot on i might try it in my lc
#107
Posted 13 November 2007 - 05:05 PM
do you need so many gauges, you have 12 counting the factory ones. I like the 4/71, it will look great when finshed. Have you thought about injection instead of a carby. A friends, cousin has a red lj 2dr with a 202 with a 4/71, glide, 9in. It was running 12sec 1/4 with a stock red, 20yrs ago.
heres a anther lc with a 4/71
#108
_why-psi_
Posted 13 November 2007 - 06:43 PM
#109
_why-psi_
Posted 15 November 2007 - 05:37 PM
#110
_why-psi_
Posted 15 November 2007 - 07:22 PM
#111
_why-psi_
Posted 17 November 2007 - 03:49 PM
put in the Pro-lite oil press warning light
trimmed where the back seat once lived
#112
_big_als_army_
Posted 17 November 2007 - 04:03 PM
#113
_JBird_
Posted 17 November 2007 - 04:21 PM
Nice trimming..is there anything you can't do??
#114
_why-psi_
Posted 17 November 2007 - 06:57 PM
thanks Jbird. i was bored lol, even bored enough to see how big a gap the msd would jump got it to about an inch and then it started jumping straight out of the lead
#115
Posted 19 November 2007 - 08:52 AM
Although my missus will have to drive my torrie.... hmmmm.....
Looking good mate.
Just hurry up and finisht he f*cker!!
#116
Posted 19 November 2007 - 06:58 PM
#117
Posted 19 November 2007 - 07:05 PM
#118
_STEVO_
Posted 19 November 2007 - 07:12 PM
looking good
_why-psi_
Posted 19 November 2007 - 09:34 PM
thanks, i used black automotive carpet we sell at my work (bunnings). made some panels up out of 9mm mdf, then just trimmed them with the carpet
#120
Posted 25 November 2007 - 11:09 AM
Edited by Heath, 25 November 2007 - 11:09 AM.
#121
_why-psi_
Posted 01 December 2007 - 09:43 AM
specs are as far as i know: 202 blue block O ringed, fully balanced rotating assembly, starfire rods, HQ racing pistons, 9 port head, copper head gasket, solid cam. Ran 12.89 @114 in an LJ with a supra 5 speed on street tyres wheelspin 1st and second and a little third. it had a small T3 turbo on it at the time.
i should be able to knock a bit off the time as my cars suspensions set up for drag and i will be running on street slicks. the 3500 stall in the trimatic will also help as will no turbo lag from the 4/71
Thanks Heath, the "torana" sign is made out of 6mm MDF, i drew it up and cut it out with a jigsaw, then used MDF primer to seal it up and then painted with GMH Orange. (same colour as the stripes on my car
#122
Posted 01 December 2007 - 10:16 AM
#123
_why-psi_
Posted 04 December 2007 - 08:58 PM
#124
_v8slrtorana_
Posted 04 December 2007 - 10:40 PM
If you have no luck with grind numbers and breed, at least you can say you did your best
Have the rockers been loosened off? Why can't you measure your cold lash average, subtract 0.002" and that should give you guide to what they should be set when hot.
You then could futher tune within 0.004" each side for best performance.
#125
_why-psi_
Posted 04 December 2007 - 10:45 PM
the rockers were off the engine when i bought it. if i cant ID the cam ill set them at a safe 0.020
