My Pro street style rear end
#126
_why-psi_
Posted 05 December 2007 - 06:40 PM
pulled the timing cover off, nothing stamped on the front of the cam.
looks like its gonna run 0.020 lash
#127
Posted 06 December 2007 - 12:20 AM
#128
_why-psi_
Posted 06 December 2007 - 06:19 AM
#129
_why-psi_
Posted 30 December 2007 - 01:48 PM
id hate to do it for a living!
#130
Posted 30 December 2007 - 07:33 PM
Any reason the carb is on backwards ??
#131
_why-psi_
Posted 30 December 2007 - 08:12 PM
#132
_lctorana71_
Posted 31 December 2007 - 11:20 PM
#133
_why-psi_
Posted 01 January 2008 - 01:10 PM
#134
_why-psi_
Posted 16 January 2008 - 08:35 PM
plan is to hide the carb inside to go for the blown injected look
#135
_UNVSM8_
Posted 17 January 2008 - 09:20 PM
keep up the good work!
Ben
#136
Posted 18 January 2008 - 07:43 AM
You sorted out a carby for it yet??
#137
_why-psi_
Posted 18 January 2008 - 05:00 PM
i need either a Holley or a Barry Grant 750 double pumper blower carb
#138
_why-psi_
Posted 21 January 2008 - 09:12 AM
will have the carby hidden inside for the blown injected look
and when i feel like having a metal mountain, i can change it to sit on top of the carb
#139
_adamlcgtr383blownchev_
Posted 21 January 2008 - 09:29 AM
#140
_v8slrtorana_
Posted 21 January 2008 - 06:05 PM
But its been so long you tyre is going flat
Keep up the good work.
Trenton
#141
_why-psi_
Posted 21 January 2008 - 07:13 PM
#142
_why-psi_
Posted 27 January 2008 - 05:51 PM
#143
_UNVSM8_
Posted 27 January 2008 - 07:23 PM
#144
_brett_32i_
Posted 28 January 2008 - 03:34 PM
#145
Posted 28 January 2008 - 03:45 PM
Have you removed some kind of spacer/adapter for these last two pics? It appears to be lower again. The butterfly valve linkage will need that hole in the bonnet to be extended I am guessing?
#146
_ChevLX_77_
Posted 28 January 2008 - 04:27 PM
Theres a torana that was featured in Street Machine from NZ that had one. BLOFLY was the number plates.
#147
Posted 28 January 2008 - 04:28 PM
Coming along nice, time to get the jigsaw out again, or i suppose you could remove the catcher each time you pop the bonnet, cause it definitely looks good with the hole nice and tight around the blower.
But if you want the catcher that low, why dont you rig up efi instead???
Use the bug catcher as a throttle body, and just graft a fuel rail and injectors on it, run it through a Delco computer or something like that, would be great i reckon.
Great work either way mate, keep it coming.
_why-psi_
Posted 28 January 2008 - 04:56 PM
going to cut the bonnet out more. mate said to just take the scoop off when i open the bonnet, but if i ever have a fire, i want to get it up pretty quick without trying to take the scoop off with flames dancing round the scoop.
#149
_NRV051_
Posted 28 January 2008 - 06:44 PM
#150
Posted 28 January 2008 - 07:38 PM
Good stuff..
