My 74 LH
242 replies to this topic
#51 Heath
  • 18,376 posts
Posted 25 June 2007 - 07:50 PM
Oooops I thought the exhaust was 12-Port Holden. And then I looked at the pics lol
Rightio
#52 ilovea9x
ilovea9x
  • 230 posts
  • Car:74 LH SL, 03 VY SS
Posted 25 June 2007 - 07:52 PM
Exhaust plates come with the head just have to do the pipes
#53 orangeLJ
Posted 25 June 2007 - 08:19 PM
my pants are stained with sweet smell of love.
gross i know. but i cant wait to get mine now!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :rockon:
#54 _ToranaGuy_
_ToranaGuy_
Posted 26 June 2007 - 04:06 PM
That head looks like it means business! :D
Nice to see there is a few guys out there still building 6cyl torana's. This should be one wild ride with a head like that being forced fed. /me druls.
I should get my ass into gear and get some more work done on my torry! It's in the shed in a similar state atm.
ToranaGuy
#55 ilovea9x
ilovea9x
  • 230 posts
Posted 29 June 2007 - 09:16 PM
Cars going to the exhaust shop tomorrow will get turbo manifold made and inlet made then hopefully intercooler pipes later down the track
#56 _ToranaGuy_
_ToranaGuy_
Posted 01 July 2007 - 10:54 PM
Awesome. Are you getting a so called tuned length manifold fabricated or just a log style manifold?
I took the easy way out, my first turbo build is using the strata manifolds. I may look at making a custom intake to make it blow thru later down the track. Might even get a custom exhaust manifold fabricated up depending on how far i can push the strata manifold.
ToranaGuy
#57 ilovea9x
ilovea9x
  • 230 posts
Posted 02 July 2007 - 07:06 PM
Wouldn't mined a tuned length manifold but might end up with a log, depends on room as my head wont fit a strata manifold, have a look at the drawing I put up on the first page and you will see why I might run out of room
#58 ilovea9x
ilovea9x
  • 230 posts
Posted 06 July 2007 - 06:28 PM
started on the exhaust manifold today, just working out all the bends pipes go in monday
#59 Heath
  • 18,376 posts
Posted 06 July 2007 - 08:28 PM
You're getting me very excited.
#60 ilovea9x
ilovea9x
  • 230 posts
Posted 06 July 2007 - 08:34 PM
Whys that
#61 Heath
  • 18,376 posts
Posted 07 July 2007 - 10:38 AM
Coz it looks freakin awesome and I wanna see what it's capable of. :P
#62 ilovea9x
ilovea9x
  • 230 posts
Posted 07 July 2007 - 05:14 PM
Estimated 500 hp at the flywheel could be more, but that�s boosting the crap out of it and putting a pretty wild cam in to
I am putting a mild turbo cam in and running low boost to start with then I will go from there
Most of the power comes from the head it can flow a lot more than the block could handle, if I wasn�t worried about the block I could get 600 plus hp at its expense
#63 Heath
  • 18,376 posts
Posted 07 July 2007 - 05:46 PM
Maybe I shoulda saved up and gotten my hands on a J-ZED...
#64 ilovea9x
ilovea9x
  • 230 posts
Posted 08 July 2007 - 11:50 PM
put your order in now and by the time its ready you will have the money
#65 ilovea9x
ilovea9x
  • 230 posts
Posted 13 July 2007 - 11:51 PM
just a update on the exhaust manifold
#66 orangeLJ
Posted 14 July 2007 - 10:07 AM
tight squeeze in there! are you making the manifolds yourself?
#67 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 14 July 2007 - 11:19 AM
Are you investing in one of 82911's crank girdles? If you intend to push the envelope then it would be worth the effort. What boost do you intend on running? With a crank girdle (and other upgraded hardware) I have seen 202's handle 30psi in circuit racing conditions.
#68 _Brewster_
_Brewster_
Posted 14 July 2007 - 01:24 PM
Interesting engine project you got going there, its certainly going to turn out to be a real monster.
Does JZed heads make ones for the VL Turbo blocks? And if so, did you consider using one of those? I've been told there a little bit more bullet proof than the standard 202 block.
#69 _gtr-xu1_
_gtr-xu1_
Posted 14 July 2007 - 01:45 PM
intresting read! what computer are you gunna run.
I hope that exhaust manifold is heavy steam pipe.
what computer you gunna run? im using haltech E6X
Edited by gtr-xu1, 14 July 2007 - 01:49 PM.
#70 ilovea9x
ilovea9x
  • 230 posts
Posted 14 July 2007 - 04:12 PM
the manifolds are being made by my brother in law
#71 ilovea9x
ilovea9x
  • 230 posts
Posted 14 July 2007 - 04:19 PM
not going that far with the bottom end, I dont what to boost it up that high and not doing that much work to the crank will hopefully stop me me from wanting to
#72 ilovea9x
ilovea9x
  • 230 posts
Posted 14 July 2007 - 04:22 PM
dont think he would touch a nissan motor
the whole point is to see what I can get a red block to do
#73 ilovea9x
ilovea9x
  • 230 posts
Posted 14 July 2007 - 04:28 PM
Was going to use a Wolf V500 but might go with a microtech
as for the pipe I did want to use steam pipe but couldnt get the right size I needed so I just used normal pipe and I will be getting them ceramic coated then they will be heat wraped
#74 _Brewster_
_Brewster_
Posted 14 July 2007 - 04:38 PM
Fair enough with the nissan thing, are you making any modifications for/to the oiling system?
Edited by Brewster, 14 July 2007 - 04:39 PM.
#75 ilovea9x
ilovea9x
  • 230 posts
Posted 14 July 2007 - 04:48 PM
I have got a oil cooler for it; I just have to find room
And for the turbos the oil line will be passing though the auto cooler in the radiator
