My 74 LH
242 replies to this topic
#101 ilovea9x
ilovea9x
  • 230 posts
  • Car:74 LH SL, 03 VY SS
Posted 13 September 2007 - 10:34 PM
Got some more updates
cut the runners down about an inch and put 45deg bends on the plenum, now it clears the bonnet. Will cut another 2 inches off the runners and then should be fine
As you can see the plenum ended up being to long we shortend the bend on the end before the throtle body and the reducer was shortend aswell, clears the bonnet by 10 mm
The plenum will be attached to the runners with sillicon hoses that way the full weight isnt on the flange and a brace down to the block will hold in place.
I could also change it to a smaller flat plate one later if I wanted, but will see how we go with this first.
#102 _tyre fryer_
_tyre fryer_
Posted 13 September 2007 - 11:26 PM
aaahhh. it's all coming together. can't wait to see it when it's done.
#103 ilovea9x
ilovea9x
  • 230 posts
Posted 08 October 2007 - 10:20 PM
My car came home last weekend and I got the shed up for the wife which should
mean no more of her crap for me to trip over in the garage hopefully.
Got started on cutting the runners down and cleaning up the welds, a lot work
ahead but aleast its home.
#104 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 10 October 2007 - 09:17 PM
Out of interest, how much does the head weigh compared to a standard head?
Tim
#105 Com_VC
Com_VC
  • 411 posts
Posted 11 October 2007 - 07:52 PM
manifold looks awesome. just one problem, how you going to get the rocker cover off to adjust rockers etc?
#106 ilovea9x
ilovea9x
  • 230 posts
Posted 12 October 2007 - 04:45 PM
unbolt the manifold and do it ?
#107 ilovea9x
ilovea9x
  • 230 posts
Posted 12 October 2007 - 04:52 PM
Tim
feels about under 10 kg, might put it on a scale
#108 ilovea9x
ilovea9x
  • 230 posts
Posted 12 October 2007 - 04:57 PM
Just an add on
I am not going to be able do it with the motor running if thats what you meant
#109 Com_VC
Com_VC
  • 411 posts
Posted 12 October 2007 - 06:13 PM
yeah would just be annoying hehe ahwell better you than me. Anyways how much power do you want from this thing?
#110 ilovea9x
ilovea9x
  • 230 posts
Posted 12 October 2007 - 06:35 PM
As much as the block stays together, but only when I want to take it to the creek, I will drive on the road with low boost, mild cam and a 3.08 diff will just cruise then change it all over for track days, its not a daily driver so I dont care about spliting the block. If it go's I will build another one
#111 Com_VC
Com_VC
  • 411 posts
Posted 12 October 2007 - 08:05 PM
600rwhp would be interesting :)
#112 _LX_SS_
_LX_SS_
Posted 12 October 2007 - 08:12 PM
i too was going to use steam pipe but couldn't get what i needed therefore i opted for some thick wall stainless piping. just what i did with my turbo manifold
#113 ilovea9x
ilovea9x
  • 230 posts
Posted 15 April 2008 - 01:15 PM
It�s been a while since I have put any new post, basically my uncle died less than a week after my last update and I lost all love for doing anything with my Torana
But last week I went back to the garage and basically just looked at the plenum and thought it was just too long, the pipe I bought in the first place only came in one meter lengths so I had another 500mm of pipe just sitting there doing nothing.
I cut an angle of 22 degs at one end of the pipe and put a 22 deg cut on the reducer giving me almost the right angle I need and as I dont have a drop saw I had to cut it with a jigsaw and then spend a bit of time with a file getting it right and now it is ready to weld and to start with the runner pipes it reduces the overall length by six inches but comes closer to the bonnet but I will work around that by reshaping the bonnet.
Before my uncle died I bought a tow car, as I was getting low in money having to get a tow truck every time the car had to go anywhere to get something done or at least that�s what I told the wife it was for when I bought it home
Here's a few pics of the plenum
#114 orangeLJ
Posted 15 April 2008 - 01:24 PM
sorry to hear about your uncle mate, but good to hear you are back into things. Sometimes the easiest way to get over something is tokeep yourself busy, and a torana is a very good way to do it! I was actually thinking about your project and why you hadnt updated anything last week.
Good to see some progress mate.
Chin up.
Chris
#115 ilovea9x
ilovea9x
  • 230 posts
Posted 26 May 2008 - 11:12 PM
Changed my mind again about the plenum, I modified the VN throttle body which now means it will bolt up without having to put a nut on the other side hence why i had the reducer.
I all ready had the VN throttle body and trying to use it was why I had so many problems, but it was a easy fix instead of getting another one that would have fitted. It bolts strait to the plenum which takes another four inches out of the total length and all I have to do now is cut the plenum at an angle which aims the throttle body at the intercooler pipe and it all clears the bonnet finally. I am getting the plenum bored out so any of the welds or runner pipes that are sticking into the plenum are removed and it is left with a smooth surface inside, hopefully that happens next week.
#116 2600s
2600s
  • 1,172 posts
Posted 27 May 2008 - 09:20 AM
Looks like a great project you have there on the go.
Attached is a pic of another Jzed head in an old Tarmac Rally car which is no longer.
"Cheers"
Alf
#117 _studricho_
_studricho_
Posted 28 May 2008 - 10:11 PM
Those heads look awesome.
#118 _TJ253_
_TJ253_
Posted 28 May 2008 - 10:17 PM
Bit late but love the new car and sorry to hear about your uncle
#119 orangeLJ
Posted 29 May 2008 - 09:06 AM
any updated pictures?
#120 ilovea9x
ilovea9x
  • 230 posts
Posted 31 May 2008 - 12:16 PM
No updates yet, working too long hours but I�m hoping next week something will happen
#121 _fat tony_
_fat tony_
Posted 01 June 2008 - 02:53 PM
Excellent project ! Just wondering what sort of figures these jzed heads flow out of the box ? they would have to be 300 + wouldn't they ?
F.T.
#122 ilovea9x
ilovea9x
  • 230 posts
Posted 01 June 2008 - 10:10 PM
F.T.
aparently mine was flow tested to 400 hp and thats what they are all made to flow.
Joe's rail the NA one has 400 hp at the flywheel, the supercharged one stated 600+ on he's web site.
Edited by ilovea9x, 01 June 2008 - 10:11 PM.
#123 ilovea9x
ilovea9x
  • 230 posts
Posted 12 August 2009 - 02:36 AM
OK been a long time since I have posted anything up, my car still looks the same as it did last year and my inlet manifold is only half done.
Changed my mine so many times about the shape of the manifold I just gave up for almost a year but started again a couple of weeks ago.
I cut a slot out of the pipe at 65mm and got some 8mm flatbar to weld the runners on, the inside of the flatbar will be bellmouthed.
Just have to get it welded.
Doesnt look like much yet but will all come together when its finaly finished.
#124 orangeLJ
Posted 12 August 2009 - 09:14 AM
Nice to see you getting stuck in again mate!
#125 _doogs_
_doogs_
Posted 12 August 2009 - 11:51 AM
Good to hear it is back on the go.
JZED heads are awesome, be good to see the figures you get when its all done.
Nice engine build.
4 user(s) are reading this topic
0 members, 4 guests, 0 anonymous users
