My 74 LH
#126 _mello92_
Posted 12 August 2009 - 10:14 PM
Absolutely awesome work mate, really hope this one gets finished.
Ive always wanted a JZED since I first saw them, so Im very interested in how this goes.
Great stuff!
#127
Posted 15 August 2009 - 01:48 PM
#128 _ToranaGuy_
Posted 15 August 2009 - 02:30 PM
ToranaGuy
#129
Posted 16 August 2009 - 09:16 PM
I thought the hoses were going to hit the grill but it only just touched here's a few pics with whole front back on
#130
Posted 17 August 2009 - 12:22 PM
100% sleeper then.
Are you going to go granny spec with the exterior? (ie. original colour paint, small diameter wheels)
or are you going for something flashier?
#131
Posted 18 August 2009 - 12:50 AM
I'm putting a hoppers brake kit on it so the smallest wheels that will fit are fifteens ( will just use commodore stockies untill funds get there )
The paint will be the same colour but with A9X blackouts on the bonnet and around windows, the bumpers and wheels are going black aswell.
The whole car is having a black and orange theme just wish the silicone hoses had more colours to chose from than blue.
#132
Posted 18 August 2009 - 09:19 AM
Actually, from memory, a joint in the UK was making intercooler sillicon joins in multi colours to suit jap cars, I'll see if I can find the link.
#133 _2X044_
Posted 18 August 2009 - 02:46 PM
http://www.otomoto.c...ping/index.html
Keep up the good work.
#134
Posted 18 August 2009 - 11:51 PM
To bad they dont make a 1 3/4 45 deg bend as I need six, will have to keep looking or put up with blue ones as I have only found one place thats sells 1 3/4 45 deg bends
#135 _ToranaGuy_
Posted 21 August 2009 - 09:57 PM
I've had a look over the original starting pics, i see your going to use a VN airbox. Good choice. I'm using one for my Turbo project. I found if i move the battery, fit the airbox in it's place i can use std black rubber flex joins to get the air from the box to my GRA 440 gas carby very neatly & it will help with engineering as the airbox has been adr approved already.
Keep up the good work!
ToranaGuy
#136
Posted 22 August 2009 - 01:43 AM
It will match the forum colours.
Lookin good mate. Keep up the good work.
Edit:what a pain in the ass to make a quote visible...
Edited by slr_v8, 22 August 2009 - 01:44 AM.
#137
Posted 23 August 2009 - 11:54 PM
My airbox has been modified just havn't put any pics up yet, there is a air intake from under the battery tray into the box and I cut the top to fit two outlets ( one for each turbo )will put pics up shortly of the box when it's finished.I've had a look over the original starting pics, i see your going to use a VN airbox. Good choice. I'm using one for my Turbo project. I found if i move the battery, fit the airbox in it's place i can use std black rubber flex joins to get the air from the box to my GRA 440 gas carby very neatly & it will help with engineering as the airbox has been adr approved already.
ToranaGuy
#138
Posted 29 August 2009 - 05:47 PM
And a few of the cold air intake
#139 _mello92_
Posted 29 August 2009 - 06:28 PM
Considering its location, Im hope you cover the mouth of the trumpet with some fine mesh, should stop larger objects camping in your airbox.
Excuse the ignorance, but why not just run two pipes off the turbos and clamp two pod filters onto them?
And is that the intercooler hose? Bit of a tight fit dont you think?
#140
Posted 30 August 2009 - 10:39 AM
#141 _mello92_
Posted 30 August 2009 - 09:48 PM
Is there any chance that airbox could be too small?
Or do I just like overkilling things?
#142
Posted 01 September 2009 - 07:55 PM
Awesome idea!
The intercooler pipe has not been cut to size and yes it is too close in the pic as it has to be pushed back to fit the box but will be fine once cut as for two pods they are not allowed by law and I don�t like sucking hot air into any motor.
The box is there for rego requirements not much street driving will be done but I want it to be all legal when it is and the box won�t be used when the car is taken to the track, there will be a wire gauze put on the bell of the intake just another of my long list of unfinished parts.
#143
Posted 27 September 2009 - 11:13 PM
#144
Posted 28 September 2009 - 07:25 AM
#145 _Viper_
Posted 28 September 2009 - 08:32 AM
#146
Posted 28 September 2009 - 11:56 PM
Was going to be one piece but decided to make it two just incase I want to change the plenum later.Looking good, how come you used silicon hoses from the runners to the plenum tho? and not just all alloy...
Injectors and fuel rail will be mounted on the runners
#147 _Viper_
Posted 29 September 2009 - 07:47 AM
Do you have ur design for the plenum made up yet? I can give you some links to some info on designs if you want.
#148
Posted 29 September 2009 - 05:24 PM
#149 _doogs_
Posted 29 September 2009 - 06:14 PM
boys in blue.
#150 _mello92_
Posted 30 September 2009 - 09:01 PM
Need I say more?
