My 74 LH
#151 _torana_49_
Posted 30 September 2009 - 11:49 PM
#152
Posted 10 October 2009 - 11:52 PM
#153
Posted 11 October 2009 - 11:18 AM
keep up the good work and keep the pictures coming.
how long ago did you buy the head? i think i read it cost you 3700?? is that complete with valves and springs?
#154 _Viper_
Posted 11 October 2009 - 12:33 PM
Did you bellmouth the ends in the plenum? also what capacity is the plenum? should be around 6L
You might find with that design that cyl 1-3 get more air then 4-6
From the research ive done... with front mounted throttle body plenums they aim the throttle body right towards the back wall and the plenum tapers as it goes towards the rear
Here's a pic of a Mclaren motor, if anyone knows what there doing they do.
Edited by Viper, 11 October 2009 - 12:35 PM.
#155
Posted 12 October 2009 - 05:54 PM
i must say i am a little suspect of those hose clamps you are using on the silicone hoses on the inlet mainifold, not sure how boost friendly they will be. where are you planning on putting the injectors?
The clamps in the picture arn't the ones i'm using just had them in the garage, will be using proper T clamps.
The injectors are going to be placed on the runners aming at the inlet valve, the head come's with valves and springs.
I havn't checked the capacity but from the throtle body to the head would be over six litres.
I am bellmouthing the inside, been doing that today.
And I cant bolt the throtle body strait on the front as it hits the bonnet, under boost wont matter.
#156
Posted 12 October 2009 - 06:03 PM
#157
Posted 12 October 2009 - 08:11 PM
[/quote]
sounds good, i will be purchasing a jzed in the new year. might give him a ring shortly to organise it. thanks for the inspiration!!
#158 _mello92_
Posted 12 October 2009 - 10:55 PM
If/when this happens, can I come to have a squiz?
Please?
ilovea9x - Mate, this is superb!
#159
Posted 05 June 2010 - 10:17 PM
Edited by ilovea9x, 05 June 2010 - 10:17 PM.
#160 _ToranaGuy_
Posted 05 June 2010 - 11:12 PM
Seeing this makes me want to get stuck into my torry again, but i have too many other projects that need time right now. :(
ToranaGuy
#161
Posted 06 June 2010 - 11:53 AM
Yeah it all fits under its that shape so it does, be a while before I find out how it gos tho.Nice dude, very nice! Great to see the updated engine pics & the engine parts pics. That turbo manifold & turbo's looks huge, is it going to fit under the bonnet?
ToranaGuy
#162
Posted 18 July 2011 - 12:31 AM
#163 _heapa_
Posted 04 August 2011 - 01:56 PM
#164
Posted 24 November 2013 - 09:49 AM
#165
Posted 17 February 2014 - 12:03 PM
Any updates on this beast?
#166
Posted 21 May 2014 - 01:55 PM
And this is the trigger wheel I'll be modifying
#169
Posted 09 June 2014 - 04:32 PM
Got this one of a mate, needs a bit of work as it has hit something but was going too enlargen it and have too drill for oil return.
Finished my alternator bracket and had too cut a section out of the sump too fit the bolt, once I check the alignment of the belt I'll weld the bracket together and get a alloy copy machined out.
#171
Posted 14 June 2014 - 10:46 PM
Fan on the alternator looks like a disaster waiting to happen, hopefully that one's just for mock up.
#172
Posted 14 June 2014 - 11:40 PM
Edited by ilovea9x, 14 June 2014 - 11:42 PM.
#174
Posted 04 July 2014 - 04:49 PM
Did you drill extra holes in the trigger wheel to mount it to the balancer?
#175
Posted 20 July 2014 - 03:19 PM
